Timing Belts
  • 18 Replies
  • 5390 Views
Offline 90Stomper
  • 427
Re: Timing Belts
« Reply #15 on: April 02, 2004, 02:49:05 PM »
Does the tensioner use a common ball bearing, needle bearing, bronze bushing or "something else?"
well since my motor is apart i just went out to the garage and looked,  it is a plastic wheel 2 1/4" dia with a metal 3/4" dia inside that rotates, cant tell what kind of bearings are in it, prob needle.   this is for a 90 tracker.  the metal part has an offset hole for the attachment bolt which alows it to pivot off center before tightening, acts like a lobe tentioner.  there is a bit more to it but you will see.  hope that helps.
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
Re: Timing Belts
« Reply #16 on: April 02, 2004, 05:03:29 PM »
I would not hurt to replace the water pump while you are there, depending on the mileage on the vehicle, they are cheap, and if you don't the damn thing will start to leak and you will have to take it all apart again to change it.
Mac
Offline Speedracer7c
  • 2210
Re: Timing Belts
« Reply #17 on: April 03, 2004, 02:06:11 AM »
What motor is he looking for. Cause the 16v is different.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Timing Belts
« Reply #18 on: April 03, 2004, 08:29:23 AM »
Mac
MAC HOW YOU DOING  ??? HAVEN'T SEEN MUCH OF YA HERE. HOW'S THAT 2 DOOR KICK/TRACK TREATING YOU. DID YOU EVER GET YOUR NEW TIRES  ???  MATTY D.  8)  P.S. MY 1 YEAR OLD REALLY LOVES YOUR SMILEY ...ITS HELL TO LOOK FOR ONE IN A CRUSH , WHEN YOU HAVEN'T POSTED IN A WHILE  ;D  MATTY D.  8)
