Oxygen sensor & MPG !!!
  • 20 Replies
  • 5144 Views
Offline Speedracer7c
  • 2210
Re: Oxygen sensor & MPG !!!
« Reply #15 on: March 23, 2004, 08:49:28 AM »
I filled up today and got 20 mpg my last tank, it was all highway driving though. I've been getting about 15 or so around town lately, I just changed the fuel filter too...anyone else get comparable mileage. Its a 95 2 door 16 valve auto.
Offline zukmon
  • 94
« Reply #16 on: March 23, 2004, 09:21:36 AM »
Does anyone have one of those A/F ratio LED gauges that hook up to the O2 port? Does it work well? I used to be able to dial it in with the sniffer down at the high school.
« Reply #17 on: March 23, 2004, 10:34:41 AM »
Same Ride, same milage.
Thinking about putting in a fuel tank out of a 4dr .
4 xtra gallons I herd.
Offline Agent Orange
  • 711
    • Trying to learn
« Reply #18 on: March 23, 2004, 11:32:26 AM »
huh i didn't know some carbed engines came with O2 sensors. why is that ? is there a servo motor adjusting the fuel mixture ?
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #19 on: March 24, 2004, 02:16:35 AM »
Hmm.  If you HAVE an O2 sensor, and it's not being used, you can use it to adjust your mixture.
You may need to add power to the heater element - I believe that when your mixture is just right, the O2 sensor puts out 0.7 volts.  You'd obviously need a digital meter, too.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Mac0
  • 91
« Reply #20 on: March 24, 2004, 12:28:31 PM »
  I'm not sure what was adjusting it - I don't have the old carb anymore.
Bobzooki - I'm not sure what you just said !!
In the last few day's I have played with it ( The Mixture screw)  drove it all day yesterday and had a shop cut out my 'Cat'. It seems to be running pretty good now. It will still run on when I turn the key off some times and I need to drop the clutch in a gear to stop it. I haven't checked the MPG yet but looking at the guage I may have slowed it down a bit. It also blows black smoke at idle - oh well -- better than before.
Thanks again for all the help.
