Hey Heather...
  • 24 Replies
  • 6199 Views
Offline 1bigtracker
  • 3409
Re: Hey Heather...
« Reply #15 on: January 24, 2004, 09:01:40 AM »
PROBABLY SMART TO GET THE 60" OVER THE 48" ONE TO START WITH....AYE.....
I thought you where from NY not Canada.   lol :P  J/K
Stu
Offline Kreg
  • 795
    • Island 4x4
Re: Hey Heather...
« Reply #16 on: January 24, 2004, 09:14:03 AM »
Ya mines a 60"
I'm just gonna mount it to the rear bumper horizonally for now.
When I have time to make some brakets, I'll do it vertically.
Offline jagular7
  • 1026
  • Jagular7
Re: Hey Heather...
« Reply #17 on: January 24, 2004, 10:55:19 AM »
My Hi Lift won't lift my truck from the front, back, or nerfs.  I either lift from the bead lock ring on my rim, or directly off the axle housing.
I value my Hi lift more than my winch and I use it far more often!
Jake Palmberg
Your situation for a Suzuki is a LOT different than the rest of us here on the list. Hell, a conv 't could probably park under the belly and those axles...... :o  Your use of a hi-lift is a fine example using the beadlock as it has a raised lip. If you didn't have the beadlocks (do you really need them on your weight?) would you have a hi-lift?
A hi-lift is a good tool for what it does. Don't forget, it could also be used as a winch. Just make sure you use rigid lines rather than a snatch strap where it'll stretch to a point.
Lenexa, KS
Offline jagular7
  • 1026
  • Jagular7
Re: Hey Heather...
« Reply #18 on: January 24, 2004, 10:57:01 AM »
Ya mines a 60"
Will it be wider than the body? Could you mount it horizontally to the tailgate under the spare? You could always as a spacer to the spare to get more room.
Lenexa, KS
Offline ksa421
  • 382
Re: Hey Heather...
« Reply #19 on: January 25, 2004, 12:01:32 PM »
Heather I was on your web site lookin around and I have a question about that front skid plate. The one that goes from the bumper to the front diff. Did that come with the bumper or did you make it? If you made what did you use and where exactly does it attach? I am lookin for somthin like that to run on mine, I have the same bumper. Thanks and keep us informed if you go SAS.
Jacob
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
Offline Jake_Palmberg
  • 43
Re: Hey Heather...
« Reply #20 on: January 25, 2004, 12:03:17 PM »
Jagular 8
said- If you didn't have the beadlocks (do you really need them on your weight?) would you have a hi-lift?
At 1.5psi you need beadlocks regardless of vehicle weight.
All of my previous zuks had 38" and bigger tires with long travel suspension, and I have always used my high lift off of the rim with or without beadlocks.
Lots of people worry about scratching the rim (chrome or aluminum), If I was really worried about that , I would quit wheeling and buy a lowered honda :o
Jake Palmberg
44'' boggers were made for samurais!
Jeeps are like tampons,,,every pussy's got one
Offline idaholwb
  • 772
Re: Hey Heather...
« Reply #21 on: January 25, 2004, 02:57:48 PM »
Heathers jack mount is a modified Hi Lift Bed mount for using the Hi Lift jack mounted to the side of the bed of a pickup. You can get one through you rlocal truck supplier that deals with Hi Lift jacks. I know, cause I work on her truck and have wheeled with her for years. I've been responsible for her building the snot out of her truck....hehe!
97 Sport
265/70-16s
2" lift
2.0 swap
Offline hcgalvin
  • 1695
    • Granite Path
Re: Hey Heather...
« Reply #22 on: January 25, 2004, 04:54:48 PM »
Jacob
Which bumper? The Calmini Winch or the Procomp Prerunner?
The part that is attached currently with the Calmini bumper came with the 3" lift brackets that you can buy from them. Those lift brackets will bring the bumper to body height (seamlessly) if you have a 3" body lift, and that heavy black metal skid that comes with it is a nice addition!
The Procomp Bumper was something we bought about 2 years ago from Procomp directly for about 90$ while they were discontinuing them.
About the SAS..
Oh yes.
I will.
;D
Heather
« Last Edit: January 25, 2004, 05:09:39 PM by hcgalvin »
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
Re: Hey Heather...
« Reply #23 on: January 25, 2004, 04:57:56 PM »
Oh yes,
It's ALL YOUR FAULT!
But..
MINE will always LOOK better than YOURS! "nyah nyah"
Heather
Heather Galvin
Offline idaholwb
  • 772
Re: Hey Heather...
« Reply #24 on: January 26, 2004, 03:46:09 PM »
 So what exactly are you sayin' Heather?? :'(
And what...you finally made up your mind about the SAS?? :o :D 8) :-X
97 Sport
265/70-16s
2" lift
2.0 swap
