No power
  • 40 Replies
  • 8423 Views
Offline Z3bra
  • 273
Re: No power
« Reply #15 on: January 22, 2004, 08:57:44 AM »
Well I just gutted my cat, and I think that some of it went into the muffler cause now it is completely nutless. I cant' get the nuts off the flange in from of the muffler so It looks like tomorrow its getting cut off and a new muffler is going on...bah
If you end up having to do this, just replace the cat with a piece of straight pipe while you're there.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: No power
« Reply #16 on: January 22, 2004, 01:19:38 PM »
BUT THEN YOU MAY HAVE A PROBLEM GETTING A STATE INSPECTION STICKER...ATLEAST HERE IN NY.....ITS GOTTA BE THERE....HOLLOWED OUT IS THE WAY TO GO ..IF YOU WANNA KEEP IT LEGAL (LOOKING)........MATTY D.
Offline Speedracer7c
  • 2210
Re: No power
« Reply #17 on: January 22, 2004, 01:37:07 PM »
Matty D Is right, gotta have a cat for legal inspection. Anyways. I gutted it with a 3/4 drill bit and a really long drill extension and just drilled it out. And vacuumed all the pieces out. It was a royal pain in the ass. THe only pieces i coudln't get out went down the pipe and Into my damn muffller. Now i got serious issues. New Muffler here I come, thats why I need pipe diameters.
  • 2274
Re: No power
« Reply #18 on: January 22, 2004, 01:46:54 PM »
I'VE BEEN CONTEMPLATING THE HOLLOWED OUT TRICK MYSELF...BUT ITS TO DARN COLD OUTSIDE TO DO MUCH WORK ON THE ZUKE RIGHT NOW  ;D
  • 2210
Re: No power
« Reply #19 on: January 22, 2004, 01:56:09 PM »
Yeah, just make sure you don't plug up you muffler! Damnit....
Re: No power
« Reply #20 on: January 22, 2004, 02:13:05 PM »
Have you checked the Cam Timing Belt yet ???
If you got missing teeth it can slip and cause
the lack of power, it will slip on the crank, and
with a 16V if it slips too much you will lunch the
valves.
  • 2210
Re: No power
« Reply #21 on: January 22, 2004, 02:44:19 PM »
Just did the timing belt last month, when the tensioner decided to let go. So I don't think its that, I do have the 16 Valve motor, I made sure the timing was right. If this cat thing doesn't work out, i'll have to look into the ignition timing.
Re: No power
« Reply #22 on: January 22, 2004, 02:52:55 PM »
Did the valves hit the pistons ???
They might have, just enough to
lower your compression and  :P
the power, has the engine been
like it is now since you did the belt ???
Check the Compression and report back
  • 2210
Re: No power
« Reply #23 on: January 22, 2004, 03:02:25 PM »
The power is the same as it was before and after the belt. I know the motor is an interference motor, so i was really particular when i put it on. So I don't think that is it. But Dont know
Re: No power
« Reply #24 on: January 22, 2004, 03:05:26 PM »
where was the timing mark that
you used to time the Cam  ???
  • 2210
Re: No power
« Reply #25 on: January 22, 2004, 03:07:10 PM »
The little dot on the gear.......thats what it was suppsoed to be I hope.
Re: No power
« Reply #26 on: January 22, 2004, 03:13:42 PM »
Yes, but where was it pointing ??
  • 2210
Re: No power
« Reply #27 on: January 22, 2004, 03:14:27 PM »
It was at 12 oclock
Re: No power
« Reply #28 on: January 22, 2004, 03:15:55 PM »
Good  :)
  • 2210
Re: No power
« Reply #29 on: January 22, 2004, 03:17:12 PM »
Thats what I wanted to hear. But like I said I think the exhaust is just plugged with cat guts. Gonna have to hack it up tomorrow. We will see how that goes lol Thanks for the help
