Ordered K&N filter today.  Will have 2hp
  • 294 Replies
  • 52597 Views
0 Members and 29 Guests are viewing this topic.
Offline bandit86
  • 1641
  • elv8rguy
Re: Ordered K&N filter today.  Will have 2hp
« Reply #150 on: January 08, 2004, 02:39:28 PM »
only if it's the one that takes up the whole back window.  It'll go with the NOS seatbelt pads.
Offline Natebert
  • 1098
« Reply #151 on: January 08, 2004, 02:39:44 PM »
Well, I put a K & N in one of these (390cid) and figured that it ought to be good for what....
...at least 300hp I think.
Stuff one of these in the ol Suzuki and hold on.
« Last Edit: January 08, 2004, 02:43:29 PM by natebert »
Offline bandit86
  • 1641
  • elv8rguy
« Reply #152 on: January 08, 2004, 02:44:00 PM »
I was thinking 302 ford with a c4.  should be pretty light and strong.  Maybe even the axles.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #153 on: January 08, 2004, 02:45:36 PM »
now with a K&N filter in that v8, may have to get a 16 point rollbar and a built in fire extinguishing system
Offline Speedracer7c
  • 2210
« Reply #154 on: January 08, 2004, 03:01:53 PM »
Don't forget chutes to slow down!! ;D
Offline Z3bra
  • 273
« Reply #155 on: January 08, 2004, 11:28:31 PM »
Now to be honest there is some validity to extra ground wires.
That said, if I wanted to put some on I'd probably just get a big piece of 00 copper cable, hook it to the negative battery terminal to make a ground bus to tap into here and there for a lot less money than some of the "JDM ground wire" kits sell for.  The gains are pretty minimal though which is why I haven't bothered with it.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #156 on: January 09, 2004, 12:21:50 AM »
OH!  I though you were hooking up a cable to the hitch and conecting the other end to a pull pal to hold back all that extra power we were talking about.  :P
32 MTR's Warn 8000i
You've All Over Looked The Most Powerfull.........
« Reply #157 on: January 09, 2004, 02:56:52 AM »
You guys and Heather (is she the only lady on the board ???)
have all over looked the most potient power mod sticker
that is known in the free world, or is it the Zukiworld ???
the two are confusing as Zukiworld is the world .......
Hi my name is Wild  and I'm a Zukahoic ....
OK back to the sticker, the most performance is gained
by installing a ZUKIWORLD.COM sticker on the top of
the windshield or across the hood, actually as long as it's
in plain view for all the free world to see it will enable the
user to climb verticle rock faces, ford 8 foot deep rivers,
and bog through the deepest mud, and the best part is
if you install it up high, all those H##ps can get an eyeful
as you walk away leaving them stuck, or better yet, while
pulling them out of their sorry stuck situation.   ;)
As far as I know you have to buy them from Eric, three
cheers for Eric, for giving us the Best Mod of All
     WWW.ZUKIWORLD.COM
;D :D ;D :D 8)
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #158 on: January 09, 2004, 04:01:28 AM »
 On that note this post should be locked, shot, forgot, and then deleted.  ::) This has been the most worthless thread ever. Is it too late to change the name of the topic? ;D Do a search for Most worthless topic and you will find this thread!
:o Mike
And to add to the bs.... A tow bar can also add some mega horsepower when attatched to the right vehicle. ;) v10 superduty?  ;D
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #159 on: January 09, 2004, 06:37:45 AM »
I don't know?  I think I'd get tired of draging that big old Ford through the woods behind my Tracker.
32 MTR's Warn 8000i
Offline 1bigtracker
  • 3409
« Reply #160 on: January 09, 2004, 07:01:46 AM »
I don't think that is what wild ment.  lata stu
Offline bandit86
  • 1641
  • elv8rguy
« Reply #161 on: January 09, 2004, 08:54:38 AM »
where do you attach the tow bar? on the water pump pulley or the crankshaft pulley for most HP gain?
Offline Z3bra
  • 273
« Reply #162 on: January 09, 2004, 09:11:50 AM »
You could always hook the crankshaft to the output shaft of a decent sized gas turbine engine.  That might make for some really strange looks.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #163 on: January 09, 2004, 09:28:17 AM »
I ordered one of these. I hear they're bio degradeable and come in many colors.
http://www.joe-ks.com/archives_feb2003/Aerodynamics.jpg
Offline Z3bra
  • 273
« Reply #164 on: January 09, 2004, 09:36:28 AM »
Plus if you get stranded you can build a campfire to stay warm and/or signal for help.
