Ordered K&N filter today.  Will have 2hp
  • 294 Replies
  • 49493 Views
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Ordered K&N filter today.  Will have 2hp
« Reply #60 on: January 04, 2004, 01:12:21 PM »
I thought these engines were good for 100,000 miles between oil changes???
You know if you grease you brake pads every 1,000 miles they'll last forever!  I'm thinking of putting a grease zert in mine.
32 MTR's Warn 8000i
« Reply #61 on: January 04, 2004, 01:13:16 PM »
That's Truth on the wiper blade,
I had an 82 Scirocco, single blade, looked cool
Offline ksa421
  • 382
« Reply #62 on: January 04, 2004, 01:13:48 PM »
what about running on just pure NOS, that should be the ultamite right? and for brakes just take one of those t-case ebrakes and but a normal disc brake caliper on it that all ya need. ::) ;D
Jacob
oh dont for get to crossdrill it!!!!!
« Last Edit: January 04, 2004, 01:19:01 PM by ksa421 »
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
Offline bandit86
  • 1641
  • elv8rguy
« Reply #63 on: January 04, 2004, 01:18:18 PM »
OMG, crossdrilled Ebrake cables are out?  I'll have to get one.  I'll pick up some 1/4 mile time with all the weight savings
« Reply #64 on: January 04, 2004, 01:20:29 PM »
A zerk in the pad, that's old style,
route a line from the front wheel bearings
to the pads, then when you fill the front bearings
the old grease automaticaly re-greases the pads,
way more trick, and you are recycleing too, remember
Earth Friendly  ;D
Pure NOS ?? Great Idea, then when I wheel at night
the after burner gets the excess and I develop 3
times more thrust  ;D ;D
Offline ksa421
  • 382
« Reply #65 on: January 04, 2004, 01:24:07 PM »
Yeah just put some spark plugs in your exhaust pipes, instant after burners thats good for 2 seconds off your 1/4 mile time atleast and 100hp bare min. also good for getting people to quit tailgaiting you.
Jacob
Offline bandit86
  • 1641
  • elv8rguy
« Reply #66 on: January 04, 2004, 01:24:32 PM »
I dont like greasing pads, I know they last longer, but it looks messy, unless you get the expensive flourescent colored greese.  I opted to make my own spacer kit so that under no circumstance will I at any brake pedal pressure ever touch the rotors.  I might try to sell some on ebay, they work really good.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #67 on: January 04, 2004, 01:27:12 PM »
Some times the old ways are the best.  Though I do like the braking ideas floting around.
32 MTR's Warn 8000i
« Reply #68 on: January 04, 2004, 01:29:46 PM »
Cross Drilled E-Brake cable ??? that
won't cool down my brake fluid, with
all this power I need a solar powered
Brake Fluid cooler.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #69 on: January 04, 2004, 01:36:06 PM »
Anybody ever ran a vacuum tube from your intake manifold to your exhaust manifold?  1st it helps to create a vacuum in your exhaust system for better exhaust flow 2nd, because you have better air flow, it keeps your muffler bearing from carboning up, hence lasts longer.
« Reply #70 on: January 04, 2004, 01:39:04 PM »
All cars have that, It's called an EGR  :P
Offline bandit86
  • 1641
  • elv8rguy
« Reply #71 on: January 04, 2004, 01:40:56 PM »
No, an EGR is too small to do any good.  You need a tube, like about 2 or 2.5 inch diameter.
« Reply #72 on: January 04, 2004, 01:48:00 PM »
Ohh those gold plated ones, Ya that's it
They sell those for the rice racers at the
speed shop in the mall, you know the one
next to Victorias Secret, BTW what is her
secret any way???
Offline bandit86
  • 1641
  • elv8rguy
« Reply #73 on: January 04, 2004, 01:51:14 PM »
her secret?  Dont tell anybody but she (all of the models) has a weenie.  I know, I got a date with one.
« Reply #74 on: January 04, 2004, 01:56:58 PM »
EUWW ...... Too much information, better
keep that one a secret, so has therapy helped
the shock of grabbing a ... Euww never mind
I don't want to know.
