Sky MFG
  • 22 Replies
  • 5215 Views
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Sky MFG
« Reply #15 on: January 16, 2004, 06:35:00 AM »
Hey Mike, I know 2 years ago you had moved your tie rods from the bottom to the top of your spindles.  Did I notice right this year that you moved them back to the factory position?
If so why?
I actually have the knuckles tapered both ways. For street use I run the tie rods in the stock location.
For offroad use I flip the tierods to the top. Many reasons for that. With them on top their is less angle on the center link. The more angle on the center link the more the front end will "plow" up on uphill climbs. This is obviosly a bad thing. Also, this creates a drastic toe change during suspension travel.  In steep downhill situations when the front end would normally squat  the toe is plowing agains itself to lift the front. (Top view/ \ ) The oposite happens when going uphill. As the suspension lifts the tires do this \ / pulling the nose down. Its really noticable, especally in moab.
Downside is that Im constantly doing "roadside" allignments. You have to "roadside" allign it each time they are flipped. It doesnt bother me cause Im pretty good at it.  None the less it can be a deturant for those who arent so good at it. Another downside is that before I can go home from an event I have to pull the front tires and flip em again. I generally flip em before I go to an event and undo it when I get home. Unless its a lond road trip like Zukimelt or Moab.
If that doesnt make sense let me know. :P
Mike
« Last Edit: January 16, 2004, 06:37:12 AM by Mikerpm4x4 »
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Sky MFG
« Reply #16 on: January 16, 2004, 06:41:08 AM »
When their on top, how does it handle?  I understand why you do it.  Why not leave it that way was my biggest question.
32 MTR's Warn 8000i
Offline 1bigtracker
  • 3409
Re: Sky MFG
« Reply #17 on: January 16, 2004, 06:41:23 AM »
has anyne bent the link on the pass. side thats going into the tie rod?
« Last Edit: January 16, 2004, 06:41:40 AM by 1bigtracker »
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
Re: Sky MFG
« Reply #18 on: January 16, 2004, 06:49:28 AM »
 Oh.  :-[ Its a little more squirlly on some roads. Nice smooth  roads its hardly noticable. Roads with a lot of .... I dont know how to describe it. :P Ya know when the road had "ruts" in it from all the traffic?  Well, those roads will keep you on your toes.
Mike
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
Re: Sky MFG
« Reply #19 on: January 16, 2004, 06:51:09 AM »
??? The sleeve? If so then Ive never heard of it.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
Re: Sky MFG
« Reply #20 on: January 16, 2004, 07:12:57 AM »
BTW I ordered an Idler. It was in stock and its on the way. ;D
Mike
SpinalTap
Re: Sky MFG
« Reply #21 on: January 16, 2004, 11:42:01 AM »
Mike
Very interested to see if it works with the Calmini idler support...if it does I'll be on the phone for both in prep for my lift and larger tires.
Re: Sky MFG
« Reply #22 on: January 16, 2004, 02:35:29 PM »
I second that..
