Second front shock
  • 25 Replies
  • 5847 Views
Re: Second front shock
« Reply #15 on: May 09, 2005, 06:12:27 PM »
one more thing, on your struts they are at there weakest point at full extension, if you were to put limiting straps on them that would be the easyest and cheapest way to make them stronger.
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #16 on: May 10, 2005, 02:28:32 AM »
Here are some more pics of it  ;)
How the shock will sit when it's on:
The lower mount:
And the upper mount:
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline 90Stomper
  • 427
« Reply #17 on: May 12, 2005, 04:01:33 PM »
cool, thanks! ;)
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #18 on: September 09, 2005, 02:59:49 AM »
brought back to the top for Hitrick
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline hitrick
  • 21
« Reply #19 on: September 09, 2005, 04:12:56 AM »
Thank You .
It look  very professional, I think this could be a great solution for me too .
I will look for someone with pro-comp 2.5 " (old kit)
« Reply #20 on: September 09, 2005, 09:02:03 AM »
Start by getting rid of the stock wimpy
struts and put in some KYB Gas struts,
you would be amazed at how much the
bigger struts help
Offline hitrick
  • 21
« Reply #21 on: September 09, 2005, 09:39:54 AM »
I have already OME installed for almost two years  .
lets say that I don't have much left in my vitara that I can to upgrage  ;) 8)
maybe to 31" tires from my 29 " MTR(goodyear) that I have now will be installed after some body-lift ( I didn't  want a body lift till now  - because it dosn't help much for off-road and has some disadvantage as I guess  You know - like car  stability because the center of gravity is getting higher )
Offline hitrick
  • 21
« Reply #22 on: September 09, 2005, 09:44:35 AM »
bigger struts help
My OME struts  are to soft for me , what brand / model of struts can You advice on ?
I prefer something that can be adjust (like the ranch 9000 I have in the rear ) .
10x
« Reply #23 on: September 09, 2005, 02:05:05 PM »
bigger struts help
My stock struts were gas. I think that maybe the early ones weren't. Koni do inserts for the stock struts, I think they're adjustable. They only list them for the early models and I assumed that was because only the early ones had non-gas struts and you have to cut the old struts to put the inserts in.
http://www.koni-na.com/pdf/boltstrut.pdf
« Last Edit: September 09, 2005, 02:30:35 PM by Rhinoman »
« Reply #24 on: September 09, 2005, 10:41:16 PM »
My KYBs have bigger tubes than stock, and
have a bigger shaft for increased strength
Gas Charged for better oil control and I think
would be a good replacement for stockers
Offline hitrick
  • 21
« Reply #25 on: September 10, 2005, 01:20:10 AM »
I had KYB in the past . it's good  and cheap compare to OME or Koni.
but I can't find it in Israel now .
