Cheaper/Easier fix!
  • 15 Replies
  • 4473 Views
Offline track_this
  • 332
Re: Cheaper/Easier fix!
« Reply #15 on: November 10, 2003, 07:08:24 PM »
any body i talk to has not yet had a fuse blow before there axle did. im thinking warn did not have a suzuki axle lying around to test exact break strength. making the hub fuse weaker by grinding on it etc. might do the trick but having it constant so you could replace it with the same strength is gonna be tricky.
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
