Rear locker for GV
  • 40 Replies
  • 11194 Views
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
Re: Rear locker for GV
« Reply #15 on: March 31, 2006, 05:35:44 PM »
but are the splines the same? size/number of splines?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #16 on: March 31, 2006, 05:40:34 PM »
From what I've gathered, yes.
The rears are where things changed as far as I can tell.
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #17 on: March 31, 2006, 06:17:45 PM »
so then, mabye this locker fit's my car? http://www.trailtough.com/sidekick.htm
but is this a lockright type of diff? how is it to use in a car that is mainly used on-road?
it's got to be hard on the axels?
and, doesn't it sound better to have a lsd in front and a lockright in the rear?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #18 on: March 31, 2006, 06:49:08 PM »
Personally I feel that limited slips are a waste.  Save your money for an ARB.
Yes, a locker is harder on driveline components than a limited slip or an open diff.  However it gains you so much more traction.  Limited slips are so limited in their capabilities offroad they're nearly worthless.
I'd bet Trail Tough's modified Lock Right would work fine, yes.
My ideal setup for a daily driver is a locker or spool in the rear axle and an open diff in the front.  If I had all kinds of money (I don't) there'd be selectable lockers front and rear.
Offline gv1600
  • 83
« Reply #19 on: March 31, 2006, 10:20:54 PM »
Hi,
As fas as i know, its possible to put  LSD at frond of a Vitara or GV, but they must have 26 spline axles.
As i know all the frond diffs have 10 bolt rings and Calmini sales an LSD for 10 bolt rings, so i think that there will be no problem.
My GV is a '03, 5,12's and 26 spline axles.
I recently changed the frond aloum diff housing and third to a steel one from V6.
A friend i have here, used to have a frond LSD in his Vitara with no problem at all.
I also believe that the trailtough frond locker will be ok for a GV too, but u must upgrade your housing and third if u want them to last longer.
A very good option will be 2 ARB's but i,m afraid of the instalation, especially for the frond diff.
« Last Edit: March 31, 2006, 10:22:57 PM by gv1600 »
Suzuki GV Calmini 2,5'' - Full Steel V6 Frond Diff - 205/80/16 KL71 -
4.24 t-case - T-Max 6500 - VTTR Snorkel - ProTrack Air-Lockers F/R
Offline sergi
  • 307
« Reply #20 on: April 01, 2006, 04:52:03 AM »
I don't know for sure if Trailtough's locker would work in our GV. I can't see why not, seeing that many people using sidekicks use the GV housings.
For a DD, an autolocker like that one could be used with freewheeling hubs. That way, on road it would be as if it wasn't there ;D. For the rear an autolocker would be nice too, but I see it doesn't work >:(.
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #21 on: April 01, 2006, 08:43:36 AM »
The problem with any full time traction adder (limited slip, locker, spool, welded, etc) up front is that if you live in a climate (snow, ice, slush, etc) where you might need to run 4x4 up front it can get interesting while trying to steer and use 4x4.  That's why I won't put one in the front of my trucks.  I don't wheel hard enough to need a front locker and I drive too much to deal with the penalties of it.
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #22 on: April 01, 2006, 12:39:38 PM »
i have also thougt about that problem, (snow & ice)
mabye it's best to leave it and save for a ARB...
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #23 on: April 01, 2006, 01:19:34 PM »
My solution for the GV will either be waiting for someone to make/adapt a locker that fits or switch to a different yet similar strength axle.  A Ford 9" appeals to me.
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #24 on: April 01, 2006, 01:45:45 PM »
mabye it's easyest to get a toyota for winter use, my mother bougt a new '06 hi-lux -great car!
but i really like my little suzuki TD!
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #25 on: April 01, 2006, 01:47:58 PM »
Yeah sure, got $25,000 US? :P
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #26 on: April 01, 2006, 01:58:46 PM »
i live in Norway, prices run a little higer here :'(
and you are not allowed to modify your car as you want  >:(
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #27 on: April 01, 2006, 02:11:51 PM »
That sucks.  It varies here from place to place.  There's always rules on mods but in some places they are simply rules for safety and in others they're super draconian stupid laws written by people that didn't know what they were doing.
Offline blacknight
  • 987
    • Gonzookin
« Reply #28 on: April 01, 2006, 06:03:53 PM »
For the rear you can put a sidekick 3rd on it and put lsd, locker, or an ARB.  This also opens up the door for gears  ;D
George
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #29 on: April 01, 2006, 06:45:58 PM »
Late '03 up use a different rear axle than the earlier GV's which used the same rear as Kicks/Tracks.  However it's still different than the XL7 diff.  Don't know what the difference is but every place with a locker that fits the early ones says it's different and won't work.
