bogs down with more throttle not fuel filter
  • 51 Replies
  • 16289 Views
Re: bogs down with more throttle not fuel filter
« Reply #15 on: March 29, 2005, 02:14:43 PM »
I had to cut the flex line in half and install
a T to hook a pressure tester to it, after all
you do is use a double barb and 2 clamps
to repair the hose, I don't know of any other
way on an 8 Valve TBI engine, 16V could have
a better way
Offline Speedracer7c
  • 2210
« Reply #16 on: March 29, 2005, 02:27:29 PM »
16 valve you just take the bolt out of the front of the fuel rail and screw in the pressure tester. My tracker had the SAME problem, turned out to be a stuck fuel pressure regulator.
Offline roadgrime
  • 19
« Reply #17 on: March 29, 2005, 11:47:48 PM »
ok i checked the alternator and coil wires both are good. im going to go down and get some fitting to rig up my pressure guage and see what my readings are.
Offline adamd
  • 369
  • sofa king we todd it
« Reply #18 on: March 30, 2005, 12:21:46 AM »
When was the last time you checked all plugs were firing? I had a V6 cavalier that wasn't firing on 1 cyl and did something similar.
'98 kick
3" B/l
30" Mud Kings
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #19 on: March 30, 2005, 03:29:49 AM »
Your cat could still be plugged..
Sometimes a way to tell is to bang on the muffler and see if anything rattles within it, like some pieces of the cat that have come out into the muffler..
But how far are you from a muffler shop? Most places will look at your exhaust system for free, to get an estimate.
Here's some steps I found on about.com:
Engine hesitates:
When you step on the gas, the engine seems to bog down or takes a second to respond.
You may notice a general lack of power. You may notice the problem when the engine is hot or cold or when you are low on fuel.
  1. You may have a dirty air filter: Replace air filter
  2. The spark plugs may be dirty or worn: Clean or replace spark plugs
  3. The spark wires may be bad: Replace spark plug wires.
  4. There may be some other type of ignition problem: Bad ignition module, distributor pick up. An engine scope is the best way to diagnose an ignition problem.
  5. If you have a carburetor, you may have a bad accelerator pump or power circuit: Overhaul or replace carburetor.
  6. The fuel filter may be clogged: Replace fuel filter.
  7. You may have water in the gasoline: Drain tank and refill with fresh, clean gasoline.
  8. Your catalytic converter may be clogged: Replace catalytic converter.
« Last Edit: March 30, 2005, 03:34:50 AM by hcgalvin »
Heather Galvin
Offline roadgrime
  • 19
« Reply #20 on: March 30, 2005, 03:33:53 AM »
just to clarify the syptom is that if i step down on the gas and hold it down it doesnt hesitate for a moment it hesitates and then gets slower and slower... so it never picks back up. im gonna drop the cat tonight and pull the plugs wires etc once iget a reading on the fuel pump
Heather nice rig you have there. pretty sure its the one parked in the lot here where i work (you left a note awhile back on my little bedlined beat up junk o matic zuki)
« Last Edit: March 30, 2005, 03:35:44 AM by roadgrime »
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #21 on: March 30, 2005, 03:35:26 AM »
Yeah, I edited my post..
I was looking at the wrong title.. I got the title right this time.. ;)
Heather Galvin
Offline roadgrime
  • 19
« Reply #22 on: March 30, 2005, 03:37:49 AM »
lol ok... looks like i have rules out 1 2 3 6 and 7 5 is invalid are there codes or anything i should look for?
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #23 on: March 30, 2005, 03:38:03 AM »
Hey, sweet! I was wondering if I'd hear from you! :)
Yeah, I work in Bldg 4L by post J7. And yeah, it is out front. :) I like the bedliner. We just need to get a lift on it!  ;D
Heather Galvin
Offline roadgrime
  • 19
« Reply #24 on: March 30, 2005, 03:39:49 AM »
lol nope to to get it running and then a lift/cage ;-)
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #25 on: March 30, 2005, 03:48:55 AM »
Sent you a PM.
Heather Galvin
Offline 6feetofAIR
  • 127
  • i wanna go to hawaii yayyyyyyyyyyyyy yy
« Reply #26 on: March 30, 2005, 09:20:12 AM »
well i just had a similar problem with the samurai, turns out my rear r&p went out as well as a rear bearing it kept getting worse the longer i drove it as well. jack up the front and rear ends and turn the tires by hand making sure if you have open diffs you have someone hold the other side to turn the r&p's, if your having trouble turning them you found your culprit. good luck, 6feetofAIR
Offline cosmo
  • 37
« Reply #27 on: March 30, 2005, 12:14:58 PM »
Check and redo your grounds.....these little guys are notorious for having bad grounds cause all kinds of gremlins.....
88.5' Samurai
Offline cosmo
  • 37
« Reply #28 on: March 31, 2005, 12:52:05 AM »
ECM also a possibility.....
88.5' Samurai
Offline roadgrime
  • 19
« Reply #29 on: March 31, 2005, 10:51:17 AM »
well it dont seem to be the grounds and just to be sure i went ahead and went through them. i was gonna replace the pressure regulator until i saw it was 100+ bucks. so i think im gonna rig up a guage right before the regulator and see what i have there and then im gonna hack off the cat...
