Sidekick - SAS - Stage 1 from 2
  • 18 Replies
  • 11543 Views
Re: Sidekick - SAS - Stage 1 from 2
« Reply #15 on: August 23, 2005, 03:26:52 AM »
Yea, Great Looking Vitara  8) I cant wait to see the final product. When do oyu think you will get your OTT and your new springs? I bet it's driving you crazy waiting to try iy out on the trail.
GRVIT
« Reply #16 on: August 23, 2005, 04:42:38 AM »
Thank you all  :)
I ll start stage 2 next week,Tuesday possibly.It includes
Phase 1
- OTT kicker 3 installation
- New crossmember and reinforced mounts for the Sammy t-case
- Custom driveshafts (temporarily)
Then I ll check it for a week and then
Phase 2 (1 week after we complete phase 1)
- QA1 coils on the front
- Panhard modification
- Custom rear A link (length aprox 24")
- Custom rear trailing arms (longer ones- heims to frame mounts and silent blocks to axle mounts)
- Rear upper coil mounts modification (will be moved lower)
- Rear lower shock mounts modification (will be moved a bit higher to gain more travel)
Offline chadstichter
  • 162
  • 98 4door home built coil yota swap 31s rear e-lock
« Reply #17 on: August 13, 2012, 04:44:18 PM »
what front axle is that
98 4door home built coil yota swap 31s rear e-locker, 8000lb winch and synthetic rope
|...BEER TRUCK..........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ]
 l(|removethispart|@) (|removethispart|@)          l(|removethispart|@) (|removethispart|@)         l(|removethispart|@)
Offline locjaw
  • 2045
  • 22
« Reply #18 on: August 15, 2012, 07:18:10 AM »
it is a 7 year old one....... the last post was in 2005  :P
i beleive that is a samurai hybred axle the galvins had for a year or two........sammy knuckles, sidekick center, (probably)sammy shafts.
good luck!
