Track/Kick Project Vehicle
  • 19 Replies
  • 10370 Views
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Track/Kick Project Vehicle
« Reply #15 on: July 20, 2005, 05:16:47 AM »
With a 3+3 lift and 32 x 11.5 MTR's, I had to trim the back of the front fenders.
Running 4.24 TC gears and 5.83 R&P, I never had a problem with the alum. front end.  All I did was to put a steel strap across the "noise" of the third member.  When you go forward the housing rotates down onto the cross member and helps support it.  When you go in reverse, the housing is pulling on the support bracket only.  I think thats where a lot of the problems happen.
As for CV's.  Stick with original CV's.  I ran my originals to death and never broke one. It wasn't untill a boot ripped on them and the CV fill with mud and sand that I had to replace it.  The last time I ran it was at the sand dunes.  It made all kinds of poping noises but held together.  Replaced them with a "Auto Zone Lift time Warrenty" ones and started braking them like crazy.  Last one went and I didn't know how or when it happened...
So get spairs or replacement ones from the bone yards.
32 MTR's Warn 8000i
Offline SnoFalls
  • 1358
« Reply #16 on: July 20, 2005, 06:00:41 AM »
Thanks for the info SnoFalls.  What size tires are you running?
31x10.50
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #17 on: July 20, 2005, 09:54:47 PM »
hey lil truck do you have a picture of this strap you put on your front diff?
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #18 on: July 21, 2005, 05:49:55 PM »
I don't have a picture.  I tried a couple times before but my camra won't focus in, in that tight of a spot.
Anyway, I come from a buggy background and you just strap the trany to the fram with a steel band and no rubber of any kind.
With my calimini 3" lift the nose of the third member was for the most part sitting on the cross member.  So I removed the rubber mount and put a 1 1/2" steel strip across the noise (in a "U" shape) and bolted it down on both sides to the cross member.
It's been like that for 4 + years and the only problem I ever had was a pinion came loose.  There is no noise transfer that I could ever hear either.
Good luck
32 MTR's Warn 8000i
Offline 1bigtracker
  • 3409
  ÂÂÂÂÂÂÂ
