mountain problems
  • 16 Replies
  • 4147 Views
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: mountain problems
« Reply #15 on: August 22, 2005, 07:31:48 AM »
Stock sammy t-case high range is 1.409
5.125 (axle ratio)            (multiplication factor of sammy High range reduction)
x  .409
2.096125
2.096125
+5.125
7.221125
7.22:1  High range rear axle ratio  is Good  ;D
YEEK!!!  YEEK!!!  YEEK!!!  YEEK!!!  YEEK!!!
Do this in one step!
Don't "drop the 1", and don't do the adding:
Your ratio should have been calculated as:
1.409 X 5.125 = 7.22:1  (same answer, but no need to split them, and add them!)
So when I calculate my lowest gear (I have the 4.24:1 transfer case, and 5.83:1 diffs), I get:
3.65 (first gear ratio) X 4.24 (low range) X 5.83 (diffs) = 90.22:1
Now THAT is an excelent rock-crawling ratio.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #16 on: August 22, 2005, 07:12:51 PM »
5.6?:1 was 2dr 1.3L Kick  or am I wrong o that one...  I forget  :-X  But the Kick with the 1.3L is one of the rarest.
That's right, I was thinking of an early Kick, but it was the 2 door 1.3L
that had the 5.62 gears, I was offered a set, did you have them Whit ???
I know it was someone here on ZW that had them
