Will this explode?
  • 43 Replies
  • 13542 Views
Offline azrocktrash
  • 121
Re: Will this explode?
« Reply #30 on: March 14, 2005, 12:02:06 AM »
they're on there. ;D i don't have a dig camera, or i would post pics.
   i expected the tire guy too cry :'(,but he just smiled and took my $$$$$.
      oscar
87 zuk,84 sj410  4 sale
come on,it' only sheetmetal!!
BODY DAMAGE IS ALWAYS AN OPTION
  ~Life begins,where the pavement ends~
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
« Reply #31 on: March 14, 2005, 07:08:23 AM »
Hey just thought you would like to know I'm running 235/75/15 wildcat all season's on my sammy with the stock rims 15x5.5 inches wide, and I run about 25 psi on trails and 35 on the street when I bother to air up, so far hasn't pulled the bead yet, but I'm afraid to lower the psi below 25 the sidewall bulge makes me nervous.
You AIR DOWN to 25PSI? With rims of that width you should be able to go lower. I run 31x11.50's on 16x5.5" rims and can run my tires at 0PSI and never lose a bead unless my front wheels are turned and up against something when I get onto the gas...
You'll have no problem running wide tires on a thin rim, you'll just need to adjust your PSI so that the entire footprint is still on the ground.
'87 TinTop
'04 F-150
Offline INGERSOL
  • 158
  • BIG, LONG, AND BLACK
    • INGERSOL.COM
« Reply #32 on: March 14, 2005, 08:30:19 AM »
The man at OK Tire tells me mounting a 225 or 235 (75-15) on my stock 5.5" wide wheel is no problem.  He said that although manufacturers dont recommend it (and he's not giving his personal guarantee that it wont pop the bead) the fellow says mounting and running that size tire on that size rim is no big deal.  He said popping the bead is not the issue, rather, the bulging out of the sidewall is the issue.  He recommended airing down to make sure the entire tread is in contact with mother earth.
Fellow also said that once the tire and rim have had time to get to know each other, the tire gets a little grove in it, kinda helping to keep the bead in place.  Hope he's right.
2003 Chevy Tracker
2.0 L Four Cylinder / 5-speed
Suzisport Headers
K&N Air Filter
Calmini Grill Guard / Tube Bumpers UK Factory Sunvisor RRO Coil Spacers Bridgestone Dueler Revo 235/75-15's
Offline r3cc0s
  • 321
« Reply #33 on: March 14, 2005, 08:38:06 AM »
acctuality from what i've heard
running a smaller wheel than recommended
acctuality gives you a tiger stronger fit at a compariable psi
as long as you're not going more than 2 or more recommended inches
Offline trackinstile
  • 435
« Reply #34 on: March 14, 2005, 01:20:06 PM »
I think it'll be ok, just go easy at first and let everything settle in.  Have fun, Dave
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
« Reply #35 on: March 15, 2005, 12:08:23 AM »
As I've said on many forums many times. You want to run as thin of a rim as you can - but still get a flat footprint with your tread. People run 20" wide 44's on 8" wide rims, and 12.50" wide 33's on 5.5" wide rims. The only reason people want bigger rims is becuase they "like the look" - or they're just stupid. Thinner rim means more contact pressure on the bead per PSI, less chance of the wheel being damaged, and 99% of the time less rubbage problems.
'87 TinTop
'04 F-150
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« Reply #36 on: March 15, 2005, 09:37:26 AM »
if that is true it will be really annoying.
It is true. Ask anyone that owns or owned a new body style Tracker 2.0 and up.
Yes there is a lot of styles in 15's but the trick is finding ones that fit. Many people have given up and just kept their factory rims.
I'm not saying there isn't any I'm saying there's not that many.
Offline bus_driver
  • 479
  • the voices tell me different things
« Reply #37 on: March 16, 2005, 05:19:09 PM »
thsi is great then I am not fubar'd......so then I will run a 235/75 full mudder and looking into the bds 2" lift  .....any rubbing issues that I should be concerned about ?? and as doing some wheeling this week end show my wife that I smash the bottom of the truck alot she agreed that armour is a priority.......maybe cuz her uncle gave me the truck ? :P
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline INGERSOL
  • 158
    • INGERSOL.COM
« Reply #38 on: March 17, 2005, 05:23:19 AM »
OK I think that clears it up for me.  I am gonna try 225/75-15 Bridgestone's on my stock 5.5" wide wheel.  I'm glad I wont have to do any figuring about backspacing, offset, and brake caliper clearance....and I think that 225's wont be so big that rubbing the frame will be an issue.  I've read a number of posts from guys with '99 and newer GV/Trackers running 225's without lift and without rubbing.  So looks like that will be my route (for now) and maybe lifts and spacers and springs and shocks and struts.....later. ;D
2003 Chevy Tracker
Suzisport Headers
K&N Air Filter
Offline INGERSOL
  • 158
    • INGERSOL.COM
« Reply #39 on: March 17, 2005, 05:25:22 AM »
By the way...thanks to TinTopper....I had no idea you could run narrow rims and wide tires.  I have been reading the tire manufacturers spec's and I figured it was just impossible to run those tires on those wheels.  I appreciatet he help.
2003 Chevy Tracker
Suzisport Headers
K&N Air Filter
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #40 on: March 17, 2005, 09:04:43 AM »
Bob there are tons of rim styles out there in 16 inch. What are you looking for? I Stare at rims all day that would fit zuks and think how they will look. I work for american racing. I'm the sales rep for utah idaho montana. So if you need to find a good deal on rims let me know?
No, No, No, it's the TIRES that are lacking.  Most tire manufacturers make damn few models in whatever the GV uses... 235-65R16, or whatever it is.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
  • 435
« Reply #41 on: March 17, 2005, 10:03:38 AM »
Yepper, now that we bought the XL-7 we're noticing that :P
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #42 on: March 18, 2005, 05:10:23 PM »
I would like to see pictures of big tires on small rims. I'm really curious as to how this looks. ???
Mean Green Wheeling Machine
Offline bus_driver
  • 479
« Reply #43 on: March 19, 2005, 03:33:46 AM »
I really wanna see pictures also....the only tires that are wide in my area on zuks are on crommy's and lowered
so if any one is running a full mud on stock  would be good to see
92 2dr soft top
235/75/15
2 inch lift
custom mud
