Testing interest: strut spacers, rear drop bracket
  • 57 Replies
  • 14560 Views
Offline SuzukHunter
  • 70
  • CAN YOU SEE ME NOW??
Re: Testing interest: strut spacers, rear drop bra
« Reply #15 on: May 14, 2005, 09:04:13 AM »
well the front strut spacers i made are 2", any more than that it really startes to throw the top of the tire out(alignment). the back was 3".its ok if the angle of your 3rd link is slightly pointing up. gives great down travel. i didnt want a whole lot of up travel, tires would be in to the quarter panel edges and posible cutting in to the tire.
« Reply #16 on: May 14, 2005, 10:15:01 AM »
I've ordered my set ;D
Can't wait ;D ;D
Offline 92Sidekick4x4
  • 1456
« Reply #17 on: May 14, 2005, 06:04:15 PM »
hey suzukihunter, what lift is in yers? heathers budget lift?
Offline SuzukHunter
  • 70
« Reply #18 on: May 15, 2005, 01:47:23 AM »
yes it is heathers buget lift.  as my truck sits, i have either traded for or built myself. well with the help of nate  and heather ;)
actually this is my third zuki body. ;D
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #19 on: May 15, 2005, 02:29:40 AM »
If you're looking for a cheap set of shocks to go with a 3" or so lift try Monroe #32162. They stretch out to over 24", they work really well on the back of mine and are longer than the crown vic ones.
Also, what is the purpose of offsetting the 3rd link mount? Does it require rotating the axle for it to work that way?
« Last Edit: May 15, 2005, 02:31:11 AM by biker »
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
  • 1456
« Reply #20 on: May 15, 2005, 05:17:20 AM »
Did you just get new shocks duane?
Offline Natebert
  • 1098
« Reply #21 on: May 15, 2005, 11:38:17 AM »
When you use larger springs, and larger shocks, you might put that upper ball joint in a bind (and could blow it out) unless you can lengthen that upper arm to accomodate the extra travel.
To help keep the pinion at a good angle you might want to  lengthen the control arms.  In which case, you can adjust the pinion agle to what ever you need, thusly rotating the axle to proper angle.
Offline biker
  • 730
« Reply #22 on: May 15, 2005, 02:29:59 PM »
I built my spacer with the holes aligned and it seems to keep my u-joint angles equal and I have no vibration. I was not wanting to do an axle rotation at this point and was curious about how the offset would affect u-joint angles and shock clearance.
Yes Spencer I put new shocks on as I folded my old ones when the rear diff rolled on me.
99 Vitara 2wd
10 Gr Vitara
  • 1456
« Reply #23 on: May 15, 2005, 04:34:58 PM »
Oh yah, forgot about that :D
Offline SuzukHunter
  • 70
« Reply #24 on: May 16, 2005, 11:40:07 AM »
yes i and nate had to rotate the axle up.had to leghten the control arms.  add a cople of brackets for the shocks and a driveline spacer.nate and heather have pictures on www.granitepath.com ;D
Offline wezzlegod
  • 227
  • under construction crowler
« Reply #25 on: May 16, 2005, 12:46:33 PM »
i would be interested .  :) :) :) i would need to know whare to find some longer springs that would fit .for both frount and rear. cheep.
Offline SuzukHunter
  • 70
« Reply #26 on: May 16, 2005, 04:57:34 PM »
well i used the springs from a grand cherokee for the rear,  fit tight so i pounded the buckets out a little. i also heated up the bottom coil and bent it in a little to fit the coil cup on the axle. for the front i went to the local spring shop and found some coils that were same size only 2"taller.  ;D
  • 1456
« Reply #27 on: May 16, 2005, 05:24:32 PM »
how mcuh for just the strut spacer?
Offline SuzukHunter
  • 70
« Reply #28 on: May 16, 2005, 05:34:47 PM »
80$ for the strut spacers and 40$ for the dif.  3rd link spacer. plus shipping, was about 10$ to portland
  • 1456
« Reply #29 on: May 16, 2005, 05:36:03 PM »
hhmmmm, ill have to think
thanks!
