Passenger vs light truck rated tires
  • 16 Replies
  • 3969 Views
Shilly
Re: Passenger vs light truck rated tires
« Reply #15 on: December 18, 2005, 07:12:19 PM »
I just draw a line across the drive and pull across it. The chalk will show on the tire and you'l know how much tread/pavement contact you have. FWIW, i use BFG A/T KO's and use 36 in the front and 34 in the back. Just remember to rotate those little doughnuts every 6K miles or so for max tread life!!
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #16 on: December 18, 2005, 07:50:59 PM »
More like feet than miles.  Also more like section than line.
The way I did it was to chalk off 6" or so all the way across the tread and then drive a couple hundred feet in a straight line.  Adjust air pressure appropriately and repeat.  I always start with high psi and go down but I guess you could go the other way too.
