Ring and pinion
  • 19 Replies
  • 5614 Views
Re: Ring and pinion
« Reply #15 on: March 11, 2005, 09:30:57 AM »
My gearing is a fair bit higher with 33x9.5s and 5:83s than it was stock. My maths says 5:83s work best with something around 31". MOAB is a bit far for me but I reckon the rest of you are going to have to form a convoy GPSs at the ready. I have a stick and so does Jimmyn.
R&Ps are expensive though. The reason why the performance drops off is because the higher gearing reduces the torque at the tyre tread. The alternative is to find some extra torque to compensate. I haven't tried this yet but maybe a header could help a lot.
« Last Edit: March 11, 2005, 09:36:25 AM by Rhinoman »
Offline ningram1
  • 84
  • 92 Tintop Vitara
Re: Ring and pinion
« Reply #16 on: March 11, 2005, 05:37:32 PM »
"Well, that's odd.  My speedo and odo are DEAD ON with the 5.83's and Goodyear Wrangler MT/R 31 X 10.50's! "
I'm running the same tyres and gearing and my speedo now reads 5 mph more than I'm doing (GPS Checked)
Stranger and Stranger....
Nick
Chaos, Panic, Disorder. My work here is done.
Offline Hard_on_riggin
  • 42
  • play in the mud
Re: Ring and pinion
« Reply #17 on: March 11, 2005, 11:28:12 PM »
I run back and forth between stock and 5.83 the 5.83 run so much better in my stick but after front diff blowes out i got to go back to stock gears  :( speedo is out with the stock gears but is close with 5.83 just a bit out calmini thinks 32" should go on but i like the 33" club and will never go back. But them tars is hard on front ends.   You guys Talk about a third member? thats not stock is it and what are you getting it out of?
Plays in the mud!!!!!
  • 42
  • play in the mud
Re: Ring and pinion
« Reply #18 on: March 11, 2005, 11:30:10 PM »
Oh ya and the header looks so cool under the hood and it makes a big improvment in tork..with high flow cat
Re: Ring and pinion
« Reply #19 on: March 12, 2005, 10:00:23 AM »
I run a complete GV V6 front steel axle casing and third member with 5:83s and the air operated 4wd engagement. My Vit (UK old shape Track/Kick) already had the 26 spline shafts.
