`03 Tracker ECL
  • 1839 Views
0 Members and 66 Guests are viewing this topic.
Offline 1985rz500
`03 Tracker ECL
« on: August 03, 2011, 03:12:38 PM »
ZR2 V6 with about 70K miles. ECL came on with a code 0335, crank speed sensor. Moved the wiring around to see if any chafing and reran the code. 0300, random misfire. Light on solid at idle, blinks when at roadspeed. Changed the plugs and air filter, no change.
Is there really a programmed service light that comes on? This truck runs like a charm, even before I changed parts.
Any ideas folks?
Still standin'
Offline DonD
  • 140
Re: `03 Tracker ECL
« Reply #1 on: August 03, 2011, 04:22:44 PM »
My high mile 4.3 threw the same codes. It was a worn dizzy gear.
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
Offline 1985rz500
Re: `03 Tracker ECL
« Reply #2 on: August 04, 2011, 06:17:39 AM »
Doing some reading, the EGR  is on the list of possible faults with a 300 code. Anybody done the r/r and cleanup on one?
Still standin'
Offline 1985rz500
Re: `03 Tracker ECL
« Reply #3 on: August 16, 2011, 06:12:26 AM »
Took the truck to a shop. Put on a commercial code reader. Shows misfire on 1/3/5 and the crank pos' sensor. The tech said it could be the wiring or the sensor or the ECM. I'll start with a disconnect and basic testing and then remove parts until I can see or get my hands on the thing.
Anybody changed one? any tips?
Still standin'
Offline Novadon
  • 205
  • South Carolina. USA
Re: `03 Tracker ECL
« Reply #4 on: August 16, 2011, 12:24:26 PM »
Are you sure that it's not the CAM Position Sensor?  ;)
03' Honda Odyssey
