1999-2005 vitara cabin air filter
  • 20 Replies
  • 8962 Views
Offline diftoyota
  • 253
« on: February 16, 2012, 04:27:39 AM »
does anyone knows if we have one or not? in the fram air filter book said i have one, i have removed the glove box and see nothing, now i am thinking they are not available in a regular vitara? my vitara is a 2002 suzuki vitara with a 2.0L 5spd. no air condition. i was looking for that as i have barly any heat. i will probably change the thermostat as i am very determined that is my problem. just wanted to get rid of that cabin filter if it has one.
Re: 1999-2005 vitara cabin air filter
« Reply #1 on: February 16, 2012, 04:46:59 AM »
There is one and it is behind the glove box.
Remove the glove box and find the recirculate intake door (move the lever between recirculate & vent and you'll see the door moving in front of you) - just to the left of that (assuming a LHD vehicle) you'll see a black plastic strip no more than an inch wide - it has clips on the top & bottom that hold it in place - unclip that and remove it and you'll find the cabin filter behind it.
You'll probably find it is choked with foam rubber - the rubber falls off of the intake door and gets trapped by the filter.
Something to consider - if you're getting airflow through the vents, the lack of heat most likely is not caused by a clogged cabin filter - you may have a "mixer door" problem or an engine running cooler than it should.
Coolant should always be flowing through the heater core as there is no "shut off" valve - what Suzuki does is control how much air flows through the core using a "mixer door".
Offline diftoyota
  • 253
« Reply #2 on: February 16, 2012, 06:18:57 AM »
i have very little wind coming out of my system so i know there is a problem there.the vent motor sounds very aggressively so that is good also, the thermostat is working fine as the needle stays at half wen running,but it may be not allowing the system to heat up enough. i do have a little bit of heat but not enough for sure. it defogs the windows a bit and thats all. and i do always use the outside vent as it always unfog the windows.
i had 2 cars before witch my problem was caused by the thermostat,my dad is a 30year + mechanic and solves that like nothing, the car engine temperature needle was at half and still i was getting barly any heat, my dad suggested me to change the thermostat and i dint listen (17 year old at the time and knew everything lol) i have change the heater core,coolant and still had little heat, then i have changed the thermostat and problem was solved, the thermostat wasent allowing coolant to flow enough to bring hot coolant to the heater core to heat up the car. as in winter the thermostat dosent let the coolant flow as much as its very cold outside
but this is my first car/truck with a air cabin filter, i figure the filter is plugged badly and stop the air of flowing, i want to remove it completely anyways as i will be in the woods most of the time and it will get clogged again quickly. also the previous owner got it stuck under a water hole after the front 4x4 air motor have failed and all the water went inside the truck, i have removed the carpet as it was ruin anyways.
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #3 on: February 16, 2012, 06:19:24 AM »
Cabin filters are on the 2nd gen Trackers also.  I opened the door on one of mine and it had no filter in it.  Most people never thought about their Zuki truck even having a cabin air filter.  I didn't replace mine.  I'm not into "filtered air" except when working around chemicals or painting.
« Reply #4 on: February 16, 2012, 10:44:43 AM »
I figure you could remove the cover, remove the filter and then put the cover back - it should work fine without the filter in place.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: February 17, 2012, 09:20:16 AM »
Mine had no filter because someone had removed it...and broken the door that covers it.
Upon putting the door back on the air flow immediately improved since I was no longer air conditioning the glove box.  I purchased a filter for it from Rock-Auto and noticed no difference in air flow.
I will say that a bunch of the listings for our vehicles are wrong.  I had to do a bunch of digging to figure out which actually fit mine and several of the "big name" filter makers had incorrect or broadly general and incorrect listings.
Offline diftoyota
  • 253
« Reply #6 on: February 17, 2012, 10:21:25 PM »
i dont know if you guys have air condition in your trucks, i dont have air condition, and by the look of it i dont have that door at all.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #7 on: February 17, 2012, 10:23:02 PM »
Should be behind the glove box once you drop it down below the normal "open" position.
« Reply #8 on: February 18, 2012, 09:02:38 AM »
That piece of plastic has a clip at the top & bottom ends - remove it and you'll find the cabin filter behind it - and yes - it does extend past the dash cross member, and it can be removed without removing the cross member.
« Last Edit: February 18, 2012, 09:09:04 AM by fordem »
Offline diftoyota
  • 253
« Reply #9 on: February 18, 2012, 03:53:36 PM »
mine dosent look like that at all. i'll take a picture to show lol
Offline bush buster
  • 263
« Reply #10 on: February 27, 2012, 01:16:44 PM »
Thanks for posting this, I also have the same symptoms.  Really sucks when it's -30C outside!  I will have to investigate this filter because if I have one it is definately clogged :laugh:
Offline diftoyota
  • 253
« Reply #11 on: March 05, 2012, 07:15:58 PM »
ok guy's here is my picture of inside my glove box. i really dont think it has an opening for a air filter
Offline gsherred
  • 112
« Reply #12 on: March 06, 2012, 05:26:12 PM »
I had to replace the blower motor in my last car and when I did I didn't get the nut that holds the fan on the motor tight enough the fan came off made lots of noise and I lost all blower output.  Also try dropping the glove box with the blower motor running and feel around under the dash for air leaks from the blower just a few thoughts.
Offline diftoyota
  • 253
« Reply #13 on: March 06, 2012, 09:00:28 PM »
no issue there so far i think its either a blocked heater core or a bad thermostat.
Offline bush buster
  • 263
« Reply #14 on: April 23, 2012, 06:32:54 AM »
Older thread but I thought I'd give an update....
I removed both filters alltogether...they were caked with leafs, feathers, mouse guts, dirt, you name it. I now have easily 2 or 3 times the air coming out of the vents.  I may install new ones for the summer when it's dusty but I think I will remove them for the winter months. Much warmer now :)
