2.0L spark plug question and torque on the top strut bolts
  • 7 Replies
  • 1815 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
« on: November 23, 2010, 06:40:56 PM »
1 - Anybody have the spark plug replacement procedure on the 2.0L I4?  Need to do mine and I have a nice set of NGK's sitting here.  Not totally familiar with this type of ignition system.
2 - What's the torque on the big bolt that goes on the top end of the front struts?  The one in the center of the strut mount inside your engine bay?  Think mine may be a bit loose.
Offline r3cc0s
  • 321
Re: 2.0L spark plug question and torque on the top strut bolts
« Reply #1 on: November 23, 2010, 07:22:47 PM »
I think its 62 & the spark plugs were really quite simple as they use coil packs...
I remember just removing the coil packs and then using a spark plug removal tool (I think its almost due time for me to do the same thing)
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: November 23, 2010, 07:25:37 PM »
97K on the stockers here.  Well past time.
Offline IanL
  • 466
« Reply #3 on: November 24, 2010, 12:30:27 AM »
Suzuki FSM - 90 N m or about 66.4 lb ft.
« Last Edit: November 24, 2010, 12:33:56 AM by IanL »
Offline Frank84
  • 176
« Reply #4 on: November 24, 2010, 05:40:21 AM »
I usually remove the strut brace to access the one plug.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
« Reply #5 on: November 24, 2010, 07:26:33 AM »
To remove the plugs - depress the latch on the coil pack connectors and unplug, remove the coil pack retaining screw, remove the coil pack by pulling straight up (sometimes it sticks to the plug and you'll need to twist it), remove the plugs with a standard plug socket and a long extension.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: November 24, 2010, 05:09:46 PM »
Thanks guys.  Sounds fairly easy. 8)
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #7 on: November 27, 2010, 09:07:33 PM »
Strut bolts were properly torqued.
Got the plugs out and they're a bit...white.  Put the new NGK's in and I can feel the difference. 8)
8"  3/8 drive extension and a magnetic retrieval tool worked wonders for pulling and placing that 2nd spark plug under the strut bar.
The 3rd coil pack back separated from the boot down in the well.  Luckily it's just a press fit and the little spring inside didn't go anywhere.  Finally worked the boot out and pushed the whole thing back together.  Runs great.
Also...something...left me a turd in front of the 3rd coil pack down in that valley they sit in.  Lovely. :-\
