2001 vitara won"t idle
  • 2339 Views
Offline zukin
  • 54
« on: October 15, 2010, 04:46:52 AM »
have a 2001 vitara 2.0 litre. has under 200kms on it.
check engine light (service engine light) came on last week.
was told to disconnect the battery to try and reset the computer.
now the engine refuses to idle, it starts fine and runs fine other than it won't idle. anyone had this problem or point me in the right direction?
thanks
Offline biker
  • 730
  • It's a sickness I tell ya
Re: 2001 vitara won"t idle
« Reply #1 on: October 15, 2010, 06:22:52 AM »
First step is to get the codes read, hard to nail down the problem by guess work. I have a reader in Nanaimo but I'm not sure where you are
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline joesteak
  • 74
« Reply #2 on: October 15, 2010, 07:52:14 AM »
YES!  get the code read before you wipe it from memory.  resetting the computer without fixing the problem wont make it go away.  might be IAC valve.  I had a problem with my 2.0L not idling, but the computer wasn't throwing any codes. turned out to be a fuel delivery issue that worked itself out.
Offline skahre
  • 22
« Reply #3 on: October 15, 2010, 07:54:42 AM »
I'm with JoeSteak all the way.  I think some of the major auto parts chains will read codes for free (hoping to sell you a part).  My money is also on the Idle Air Control valve, but don't assume its busted just because it threw a code and quit.  CHECK THE WIRING AND THE CONNECTOR before you buy a new one.
'02 Tracker 4dr 4X4
2.0L, 5-Speed
Stock except:
215-75R15 AT tires
Drilled-out airbox w/ K&N
Offline sir lance
  • 342
  • I love my XL-7
« Reply #4 on: October 15, 2010, 06:52:30 PM »
had the same problem with my xl7 after i disconnected the batt, i know it sounds strange but all i had to do was start it and keep the rpms up for a few mins and give the comp a chance to relearn itself.
this may be all it is..... scared the crap out of me when it happend that's for sure
perhaps drive it around for a while as well
-Lance
