A-Arm Ball Joint Boot
  • 9 Replies
  • 2586 Views
Offline JayInBarrie
  • 107
« on: April 06, 2010, 01:34:44 PM »
The Boots protecting the ball joint have quickly started to fall apart!! :(
http://s305.photobucket.com/albums/nn204/jayinbarrie/A-arm%20Ball%20joint/?action=view&current=DSC00208.jpg
http://s305.photobucket.com/albums/nn204/jayinbarrie/A-arm%20Ball%20joint/?action=view&current=DSC00209.jpg
http://s305.photobucket.com/albums/nn204/jayinbarrie/A-arm%20Ball%20joint/?action=view&current=DSC00210.jpg
The Boot is part of the  A-arm.  What suggestions are there for replacing the little, small, cheap, rubber boot.  Not the large, expensive A-arm???  I want to make sure dirt doe's not destroy the ball joint.
99 2dr Tracker, 33" tires stuffed in, home made roof rack.
Re: A-Arm Ball Joint Boot
« Reply #1 on: April 06, 2010, 02:16:24 PM »
Energy Suspension makes ball joint boots - I'm not going to tell you they make one specifically for whatever it is you're driving, but it's a place to start.
Offline JayInBarrie
  • 107
« Reply #2 on: April 06, 2010, 04:44:12 PM »
Great I think that'll work.  Just gotta measure and check the parts store  ;D
I'll try and follow up with how it go's.
I'm little concerned about how it'll attach, since the factory boot is sealed or press into the control arm.  I'm sure I can fandangle something.
« Reply #3 on: April 06, 2010, 08:31:50 PM »
*coughCalminiLiftcough*
Offline IanL
  • 466
« Reply #4 on: April 07, 2010, 12:06:31 AM »
Suzuki Part :  Seal Set 45706-60A00.  (Also fits Gen1)
Offline JayInBarrie
  • 107
« Reply #5 on: April 16, 2010, 07:21:02 PM »
Hey my birthday's coming up.... :laugh:
I'll pull the controll arm and take it to the dealership to check on that seal set.
Thanks.
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #6 on: April 25, 2010, 03:15:56 PM »
JayInBarrie; Have you pulled one of your A-arms and checked out the "seal deal" yet?
Offline bzzr2
  • 1011
« Reply #7 on: May 02, 2010, 03:48:28 PM »
get that shit working for suzican!  my junk broke over the weekend but is fixed now..  front diff bracket.... pos.   what are you running for rear shocks?  i blew both my cavalier shocks and might try something different, they have good travel though...
09 taco reg cab short box 4x4
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #8 on: May 08, 2010, 02:04:31 PM »
For all the guys who go buy the EBAY or jobber lower control arms. Replace the boots with suzuki ones. My jobber control arm boot is cracked after 1 year.
bzzr2 use a set of ranhco rs5000 ive got 130,000km on mine. Buddy has over 80,000 on his and he off roads alot
01 GRAND VITARA
Offline JayInBarrie
  • 107
« Reply #9 on: May 24, 2010, 04:08:07 AM »
I check out a couple of parts stores and nothing.  One guy even rumaged around and gave me a couple of boots off of spare parts.
Ended up buy the boot seal from the stealership.  Didn't take many pics, I'll try and get them up later.
The old boot has a wrap around spring that holds it on, you gotta really clean the base of the boot to see it there.
The new boot ($26 from the stealship) comes with a little grease pack and wire.  Instructions say not to use the old spring, but to wrapped the wire around twice and twist tight.  The instructions show the boot for the tie rod end.  Looks like the same boot.  The tie rod end boots would be EASY to pull at a yard if actually are the same boot.
