Anyone have probs with the power windows
  • 1808 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: May 29, 2005, 11:37:37 PM »
Question anyone have issues with there power windows i dunno weather or not the passenger rear window motor is fucked but i think it is cause my main fuse kept blowing and i could not get the window up so i manualy cabled it up and me being the bright one i think i hooked the motor back up when i put the door panel up and i flicked the switch and burned my last main fuse rrrrrrr.
01 GRAND VITARA
Offline sergi
  • 307
Re: Anyone have probs with the power windows
« Reply #1 on: May 30, 2005, 02:13:21 AM »
I've had issues, sometime it won't go up the last centimetre. That is because it tilts forward and it eventually gets stuck...
Never heard of your problem though ::)
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline Guardrail
  • 101
« Reply #2 on: June 30, 2005, 01:03:01 PM »
Yeah, I have a problem with power windows.  My problem is, I don't have any ;D ;D ;D
Can he say that here
Later,
Guardrail
Offline the_maplebar
  • 466
« Reply #3 on: July 01, 2005, 02:25:48 AM »
I've had that too.  On the trackers they issued a service bulletin on this.  I don't know that the dealership actually did anything other than reseat the window and tighten things up a bit, but it does seem better now.
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« Reply #4 on: July 09, 2005, 05:01:06 AM »
The drivers side front window on my Tracker tilted a little as it slid up. I fixed it myself by tightening up the phillips head screws (two of them) that holds the glass to the regulator. My passenger side front glass was a little tight, I tightened up the same screws and problem solved again. There isn't much to adjust or go out of adjustment back there (two phillips head screws) so don't be afraid to check things out your self if you are machanicly inclined.
NOTE; If still under warrenty do not tear the splash guard just incase you got to take it to the dealer. Put things back in the same order you removed them.
If you got screws or clips left over after assembly they are not spares! It means you forgot something ;).
