Back from the dead with a Tracker Q"
  • 7 Replies
  • 1182 Views
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« on: March 10, 2009, 07:19:50 PM »
Well I'm back. It's been awhile but i have some serious stuff going on :o
I just picked up a 00 chevy tracker 4dr 5spd 4x4 2.0.
I think the tcase is JACKED. It, Or the tranny makes some wicked noise when off the gas.
What Tcases work with this tranny? And what tranny works with the 2.0?
PLEASE Help...
Mike.
As we moving with the speed of the robot sonic exhaust
Chronic fumes, fuel, gin, and tonic
Half of the world is corrupt and alive
The other half is depressed and they want to die
Offline trackinstile
  • 435
  • Too young to quit........Too old to change........
Re: Back from the dead with a Tracker Q"
« Reply #1 on: March 10, 2009, 07:23:46 PM »
Just curious, does it do it in 2WD or just in 4WD?
A wise man once said, "Wherever you go...........There you are.............." 2000 Tracker 4 door with the 2.0 liter "Big Block". 5 speed 4WD  2001 XL-7 EX II
Offline zookiemike
  • 474
« Reply #2 on: March 10, 2009, 07:28:41 PM »
It seems all the time?
Offline IanL
  • 466
« Reply #3 on: March 12, 2009, 02:35:55 AM »
Complicated.  There are two designs of TC front for Suzuki Vitara and GV.  They look very different.  One type is used on AT, the other on MT, except with the 2 litre, where the AT type seems to be used on the MT.  For the XL-7, the MT type was used on the MT up to 2002, then it switched to the AT type.
Best thing would be to get transmission and TC from the same donor.
No info about Trackers, but you'd expect them to be the same as the Vitaras.
Offline zookiemike
  • 474
« Reply #4 on: March 12, 2009, 04:45:52 AM »
Oh I know It's the same as a vit. I just need too know if it's just the spline count on the output that's different?
Offline IanL
  • 466
« Reply #5 on: March 13, 2009, 02:08:51 AM »
Well, I can tell you its the same part #s for the output shaft and slip yoke on the 1.6 and 2 liter models, but different on 6 cylinder models.
Offline zookiemike
  • 474
« Reply #6 on: March 13, 2009, 05:00:57 AM »
Well that's good to here ;D
Offline sir lance
  • 342
  • I love my XL-7
« Reply #7 on: March 14, 2009, 10:29:09 AM »
all i know is that the grand vitara v6 manual trans and auto trans have different output spline counts, (same goes for the xl-7's)
 for exsample a 1993 sidekick transfercase will bolt up to an auto tranny from an automatic grand vitara with a v6 (i know this because i have a kicker 2 bolted up to mine) but  the same case will not bolt up to a standard trans
dont know is that helps any, but this is what i know......
-Lance
