2"body lift- Engine bay strut
  • 1611 Views
Offline Browning
  • 24
« on: June 04, 2018, 11:50:29 AM »
Just curious what people are doing mainly for the engine bay strut brace? Cutting around the body or making custom extensions for the brace itself? I'm thinking of making custom extensions but I'm curious if the strut is used at all in any tire adjustments as I see slotted holes as well?
I like tight lines, big racks and sweet lines, I’m just a sofisticated Redneck!
Re: 2"body lift- Engine bay strut
« Reply #1 on: June 04, 2018, 05:19:24 PM »
The strut brace is not used in any adjustments, but, it's presence IS critical to the camber settings (the strut towers sag inwards if you leave it off), and your "custom extensions" or spacers will have an impact on the camber if not correctly done - if you're using camber bolts, you can probably tweak those to get the adjustment correct.
Offline Browning
  • 24
« Reply #2 on: June 04, 2018, 10:20:16 PM »
Thanks for the reply, i made two extensions 2” but we’ll dry fit it to see but worst case i will cut some sheet metal...
Offline Browning
  • 24
« Reply #3 on: June 05, 2018, 08:44:19 AM »
Well I tried to fit the extensions but the increase in height brought the centerlines in, so just be easier to cut some tin!   :o
Offline olija
  • 770
    • Check out my cardomain
« Reply #4 on: August 08, 2018, 10:09:15 PM »
I tried the same thing, ended up just cutting the holes wider. Takes 5 minutes and costs nothing. How can you go wrong?
