Click on accelerator. pedal ?
  • 1340 Views
Offline Racegun
« on: July 30, 2010, 09:21:22 PM »
We  have an annoying click on the accelerator pedal and or right side firewall when turning right at low speeds, it only clicks once.
This is an Aussie 2003 G V 2.5 and the pedals are on the right,
Anyone have any ideas thanks...?
Offline Racegun
Re: Click on accelerator. pedal ?
« Reply #1 on: August 04, 2010, 01:17:07 PM »
Any ideas anyone , is there a solenoid connected to the throttle somehow or is something in the suspension/steering at fault , maybe a cv joint even , I can't find anything worn or loose ?
Offline IanL
  • 466
« Reply #2 on: August 05, 2010, 03:53:37 AM »
I've known this on other vehicles, so it may be worth mentioning:  The firewall has a dent in it, which causes it to flex under some conditions - sort of click-click.
Offline Racegun
« Reply #3 on: August 05, 2010, 04:41:24 PM »
Thanks I will investigate further.
