Clunking Noise
  • 9 Replies
  • 4591 Views
Offline 1985rz500
Clunking Noise
« on: May 21, 2010, 10:10:58 AM »
Have an `03 ZR2 4dr, 60K miles, never been offroaded.
Has a loud clunk when you go over a bump with the wheels turned. Or if you drive in a straight line and turn hard left to right and back. No difference if I shift into 4wd. Nothing comes through the steering wheel and the truck drives perfectly under normal conditions.
Garage sz the bushings in the front diff supports may be the culprit.
Is this normal wear?
Anybody changed them?
« Last Edit: May 21, 2010, 10:12:32 AM by 1985rz500 »
Still standin'
Re: Clunking Noise
« Reply #1 on: May 21, 2010, 03:50:52 PM »
Sway bar - check the D rubbers that hold them to the chassis rails and the end links.
Offline 1985rz500
Re: Clunking Noise
« Reply #2 on: May 21, 2010, 03:54:39 PM »
Thanks fordem, we checked the sway bar mts and ends. First thng I thought it was but all is nice and tight there.
Still standin'
Offline TopHeavy96
  • 488
Re: Clunking Noise
« Reply #3 on: May 21, 2010, 07:32:08 PM »
Strut mounts?
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Clunking Noise
« Reply #4 on: May 21, 2010, 08:41:38 PM »
I haven't heard of the diff mount bushings having to be replaced.  How about... if you had the front struts of your truck replaced recently, llift the hood and check to see if they replaced those 1/4 inch thick rubber bushings under BOTH of the metal washers under the top strut mounting nuts.   Even though there is a 1/4 inch gap there everytime your strut mount flexes it allows that metal washer to contact (pound) on the metal of the truck body which seems to get transfered to the frame.  If one of these (or both) is missing every time you hit a small bump it will sound like someone is beating on your suspension with a sledge hammer. This makes a "banging" noise though, not a "clunking" noise.
Offline johndb
  • 26
Re: Clunking Noise
« Reply #5 on: May 22, 2010, 07:15:09 AM »
Double check your swaybar end links, the ball and socket will wear and make noise but still feel tight as there is a lot of pressure on them. Maybe pry on them and see if there is play in them. It took mine finally breaking before I could find the noise. Just my thoughts.
Offline 1985rz500
Re: Clunking Noise
« Reply #6 on: May 26, 2010, 06:21:24 AM »
Thanks for the input folks. I bought the truck with 20K miles on it so I doubt that the struts had been changed. The garage checked the truck over on a two post hoist  with the suspension fully extended. Dumb question, but would it really make any difference with the truck say, on the ground?
Still standin'
Offline 1985rz500
Re: Clunking Noise
« Reply #7 on: July 07, 2010, 06:31:19 AM »
Bingo! right you are. Right side was shot, don't know how the garage missed it. Imagine swapping out those diff support bushings and still having the noise?
Changed them both while I did the rotors and pads, thanks johndb
Still standin'
Offline johndb
  • 26
Re: Clunking Noise
« Reply #8 on: July 08, 2010, 09:46:11 AM »
Glad I could help.
Offline bzzr2
  • 1011
Re: Clunking Noise
« Reply #9 on: July 09, 2010, 10:24:14 AM »
ha, just an fyi my diff bushing toward the rear is shot, so this can happen, but i wheel mine.
09 taco reg cab short box 4x4
