Dented Chasis
  • 2009 Views
Offline sergi
  • 307
Dented Chasis
« on: September 20, 2005, 05:02:11 AM »
I rotated my wheels the other day (they will get changed some day ::)), and noticed a dent and bump on my chassis. It's on the front right, right where the flat part of rail goes upwards toward the spring perch.
You can see a bump on this side of the rail:
This circle is totally deformed,and you can see the bumps on either side:
This is the other side, how it should be:
I wonder how I hit that part so hard yet the catalizer which is right next to it is intact.
The question is, should this be adressed? I am not worried about it right now, just thinking that on the long term it might get worse. Hasn't anyone experienced this? Any solutions/reinforcements needed?
Thanks for any help! :)
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
  • 6575
  • 66
Re: Dented Chasis
« Reply #1 on: September 20, 2005, 06:12:44 AM »
I would suggest welding a plate along the face of the verticle side of the frame. It wouldn't have to be too big. This would keep the frame from buckling and you actually having a problem. Something similar to the way Hagen reinforced his frame modifications on project "RockStar". That should work.
Good Luck, Eric
Offline sergi
  • 307
Re: Dented Chasis
« Reply #2 on: September 20, 2005, 07:01:48 AM »
Thanks!
Do you mean something like this?
Foto by Mike Hagen at http://www.zukiworld.com/month_010105/feature_operationrockstar_partone.htm
So a few plates on top (without cutting my existing frame ;)) and that should be it... I'd better start practicing my welds ;).
Thanks!
Barcelona, Europe
  • 6575
  • 66
Re: Dented Chasis
« Reply #3 on: September 20, 2005, 07:05:09 AM »
Thanks!
Thanks!
Yes, like that only you don't need to cut the frame and probably wouldn't need a plate anywhere near that big.
.... but that is the idea.
Offline trackinstile
  • 435
  • Too young to quit........Too old to change........
Re: Dented Chasis
« Reply #4 on: November 06, 2005, 03:51:28 PM »
Sorry for the late post but it almost looks like it slipped off a car lift, I've seen this before, just a thought.  Dave ;D
A wise man once said, "Wherever you go...........There you are.............." 2000 Tracker 4 door with the 2.0 liter "Big Block". 5 speed 4WD  2001 XL-7 EX II
