Diagnostics port?
  • 18 Replies
  • 2826 Views
Offline FNG
  • 197
  • 91 TRACKER 6" LIFT ON 34S, SKID PLATES AND CAGE
Re: Diagnostics port?
« Reply #15 on: July 26, 2006, 07:18:15 AM »
 Code 0440 or p0440 is fuel tank vent system- above limit. no change to fuel mixture is seen
when purge valve from canister is opened.If this fault returns pm me and i can give you more
info for diagnosis.
Offline Jeff@TireBalls
  • 559
« Reply #16 on: July 26, 2006, 10:07:56 AM »
Thanks FNG!!!! So far I've put about 300 miles on it since and it still hasn't returned.
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Offline FNG
  • 197
« Reply #17 on: July 27, 2006, 05:55:58 AM »
Thats good because canister faults can be a pain to find.Was it siting for a while before you bought it?That can cause faults with solenoids sometimes.Hopefully the fault will not return
 ;D
  • 559
« Reply #18 on: July 27, 2006, 08:00:38 AM »
I'm not sure, it was on a car lot. It came on after about 100 miles.
