CALMINI ADJUSTABLE REAR TRAILING ARMS part no' : sk198002
  • 1109 Views
Offline sherifon
  • 42
« on: October 30, 2006, 06:37:21 AM »
hello  to  all
 i  currentlly  run  on  the  2.5" calmini  lift , the ride is very  nice  .
 recently  i  was  thinking  of     those CALMINI ADJUSTABLE REAR TRAILING ARMS  sk198002,
i  want  to  understand  the  importance  of adding  this  part  to  the exsisting  lift
  what  will  i  gane   by  having  those  arms ?
 do  some  one  have  better  solution ?
« Last Edit: October 30, 2006, 09:57:07 AM by sherifon »
Re: CALMINI ADJUSTABLE REAR TRAILING ARMS part no' : sk198002
« Reply #1 on: November 03, 2006, 09:37:19 AM »
I installed the arms with the 2.5" lift. The arms allow you to adjust the drive shaft angle to compensate for the lift. I did notice some vibration after I installed the lift and adjusting the arms did reduce it. I believe the shop that did the alignment also adjusted the arms to fine tune the alignment.
I found the ride with the lift very harsh but they do advertise it as a heavy duty spring.
Offline sherifon
  • 42
« Reply #2 on: November 03, 2006, 12:14:09 PM »
Busted Knuckle  thanks, but  this  wasn't    the answer  i  axpected   ???.....
  no  vibes  here ;)
  i'm  more  interested in understanding  the  upgrade   that  is achived  buy  those  arms..... ::)
someone  more?
Offline atc_gv
  • 76
« Reply #3 on: November 03, 2006, 02:15:29 PM »
The upgrade is to be able to adjust your drive shaft angle to iliminate drive line vibrations and prevent u joint failure. At least thats what I get out of it. Every vehicle  reacts different to lifts. I have some decent vibes with my spacer lift.
« Last Edit: November 03, 2006, 02:17:53 PM by atc_gv »
