GV likely goes under the knife the first weekend in June
  • 93 Replies
  • 16331 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: GV likely goes under the knife the first weekend in June
« Reply #90 on: October 24, 2006, 08:44:02 PM »
Hey man shot me a email to jpbauto|removethispart|@yahoo.ca
The front camber works. Im gonna look for some pics exactly what we did.
The 4cyl lift 2" in the front and the gv 1.75" due to the engine weights. the rear is the problem as im runnin a  2.5" spacer in the rear and its pulling the brake line. Im trying to get a shop to make me lines but its taking longer then i wanted.
Im gonna contact earls again and see what we can fab up. I did a 3" spacer for the rear and its sits nice but u can not drive it with the stock brake line and the pan hard bar is being pulled a bit.
Ill play with it this winter and so forth
If anyone has questions email me jpbauto|removethispart|@yahoo.ca or call me I will help.
josh
01 GRAND VITARA
Offline bzzr2
  • 1011
« Reply #91 on: October 29, 2006, 03:57:45 PM »
here's pics of mine with the lower hole ovaled, front spacer is 1inch from JDMCRX.  works great.
« Last Edit: October 29, 2006, 04:01:41 PM by bzzr2 »
09 taco reg cab short box 4x4
Offline IanL
  • 466
« Reply #92 on: October 30, 2006, 12:16:19 AM »
Nice pics.  The trick I saw is, once you are happy with the position, tack weld a washer to the strut to fix the new position.  Should prevent slipping under impact load.
Offline JDMCRX
  • 1110
« Reply #93 on: October 30, 2006, 07:46:48 PM »
Yeah that would work too :)
01 GRAND VITARA
