Gv rear differential interchange
  • 2733 Views
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« on: November 06, 2019, 11:26:17 AM »
Hi my daughter has an 03 gv auto rear diff has bearing noise i would like to know what other 3rd members will drop into it.  Was making noise when she bought it. I think it got run dry so just wantbto swap it out. If you have one in sw Washington for sale i may be intrested  thanks.    I did try the search with no luck
Re: Gv rear differential interchange
« Reply #1 on: November 06, 2019, 08:50:08 PM »
You'll need to match the axle ratio so the only thing that will swap in there is a third from another auto transmission GV - I think all 99~05 used the same 4.875:1 gears, so in theory any one can work, but, I am aware of part number differences, so I suggest you stick with an 03.
Offline Novadon
  • 205
  • South Carolina. USA
« Reply #2 on: December 21, 2019, 06:38:56 AM »
2WD and 4WD vehicle gear ratios often differ, as delivered. Check / evaluate what you have installed. Google how to determine your existing ratio. It's the safest move.
And the noise...not (instead) wheel bearing related I assume?  ;D
03' Honda Odyssey
