Installation of air lift 1000 in front coils
  • 1601 Views
Offline zuki709
  • 190
  • 6
« on: November 07, 2011, 05:52:23 AM »
« Last Edit: November 07, 2011, 09:11:37 AM by zuki709 »
91 Samurai in many pieces
01 Tracker MUD CHILD's 2" suspension lift & 2" body lift. air lift air bag 1000 in front. 31x10.50X15 on stock samurai wheels.
Offline IanL
  • 466
Re: Installation of air lift 1000 in front coils
« Reply #1 on: November 08, 2011, 12:49:51 AM »
Do the airbags, when not inflated, act as effective bump stops?
Offline zuki709
  • 190
  • 6
« Reply #2 on: November 08, 2011, 05:36:10 AM »
That is a good question. In the installation sheet it say not to use them as bump stops. But in the installation instruction for the rear they tell you to cut the rear bump stops off. I will personal be using them as my bump stop. The say to leave a minimum of 5psi in the at all times, I do not think the coil will compress the full way with the bag inflated that much. It does not ride any different then it did before adding the air bags with 5psi. I think they will act as a good bump stop considering they are good for 1000lbs. I know Medford on here told me in a earlier post I started about the air lift that he was useing his as soft bump stops. It's better then no bump stop. ;)
Offline tcfootball
  • 82
« Reply #3 on: November 10, 2011, 10:38:58 PM »
Sweet!  Looking forward to the pics of the plow mounted up.
Offline tcfootball
  • 82
« Reply #4 on: December 24, 2011, 03:07:45 PM »
Pics of the lift, and of the plow!
Offline zuki709
  • 190
  • 6
« Reply #5 on: December 27, 2011, 03:03:21 PM »
i got the rear breaks apart right now but as soon is i get it back together i'll snap a few pic's.
