Lets see your ride!!!
  • 352 Replies
  • 137326 Views
0 Members and 22 Guests are viewing this topic.
Offline bzzr2
  • 1011
Re: Lets see your ride!!!
« Reply #120 on: May 11, 2009, 08:16:16 AM »
my 03 ZR2 with the recently added hardtop that i'd be happy to sell real cheap! (my mounting bolts are totally f'ed so I can't mount it properly) and the newly updated tires, 31x10.5 SSR's, these things are huge for 31's as they measure closer to 32!  turns out they work better than my last swampers too.  had to do some internal trimming/banging to make these fit, they still rub in the back a little but only on plastic, if i extend the bump stops with will go away.
« Last Edit: May 11, 2009, 01:11:49 PM by bzzr2 »
09 taco reg cab short box 4x4
Offline metoo
« Reply #121 on: May 14, 2009, 03:38:55 PM »
03 vitara sas, 33pro comp extreme mud, 5.13's, locked in rear, custom built long arms, 3 link in back, 4 link in front, with power steering box from 97 sport sidekick, First trip out, one long winter build works fickin awesome
« Last Edit: May 14, 2009, 03:54:10 PM by metoo »
Offline TopHeavy96
  • 488
« Reply #122 on: May 14, 2009, 03:48:46 PM »
Hey metoo, nice rig, looks mean!
Offline metoo
« Reply #123 on: May 14, 2009, 03:56:43 PM »
thanks, i guess when u live in Canada and the winters r so damn long u have enough time to build somethin lol...
Offline dentedzuk
  • 171
« Reply #124 on: May 15, 2009, 10:08:42 PM »
your truck is everything i wish mine could be!   :'(
2001 2.0L 4dr Vit: Calmini 2.5" susp, 215/65R16's, Surco safari rack, cone filter, turbo muffler!
***FOR SALE***
2" R.R.O. B/L w/ steer extension - $125
Trackkick axle, $50
stock Vit springs - $50
2x 225/75R16s A/Ts(95% tread) -$85
pics- http://www.zukiworld.com/forum/index.php?topic=24765
Offline Sn0vv
  • 143
    • Cardomain Profile
« Reply #125 on: May 16, 2009, 11:04:20 PM »
You know most ppl DRIVE their 4x4s in the winter lol
2000 Cheverolet Tracker 2.0L 4cyl 5 door hardtop
with all options and 4x4 to top it off
Offline olija
  • 770
    • Check out my cardomain
« Reply #126 on: May 19, 2009, 07:02:39 PM »
01 Vitara 2.0L 5 speed
Calmini 2.5" lift, Masterkit1 2" body lift
31x10.5 Westlake CR857 M/S tires on 15x5.5 Suzuki Sidekick "bullet-hole" rims painted black, yes, they rub on the frame on really tight turns
5.13:1 diffs, 4.24:1 Trail Tough low range gears, Detroit Locker rear-end, Superwinch premium manual locking hubs
Panasonic CD/MP3 deck
swaybar got tossed in the basement
custom skid plates and rock rails in the works
It's pretty neat looking, works superb off road, not too bad to drive on road either cause I got 5.13's.
Offline TopHeavy96
  • 488
« Reply #127 on: May 19, 2009, 07:14:53 PM »
Nice ride!!  Pretty blue bits! ;D
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
« Reply #128 on: June 20, 2009, 09:52:48 PM »
Hello everyone.. I'm from Trinidad and new to the forums!
I've got a 1998 2.0L SGV. Vehicle is lightly modified with the 2.5" Calmini lift kit and some Hercules Terra Trac AT rated Tyres..
went with some friends for a drive down Icacos beach in Trinidad..
future upgrades
-install a locking rear differential
-install lots of off road lights  ;)
« Reply #129 on: June 22, 2009, 09:11:35 PM »
I know this thread is alittle old, but I thought I'd post my 2000 Tracker.
Ok, got the Calmini lift and got it installed.
Next up is installing my body lift and fitting 31's.  How much rubbing will I have with a 3" suspension lift and a 2" body lift with 31's?
Offline olija
  • 770
« Reply #130 on: June 22, 2009, 09:28:13 PM »
Barely any! If you run those same wheels you have in the picture, your only rub will be when you turn super tight, it will rub on the frame behind the front wheel, and on the A-arm in front of the front wheel. The rear wheel will rub on the plastic inner fender liner, but it's fairly minor. If you get wheels that stick out more you will need to trim alot!
Offline 3stagevtec
  • 204
« Reply #131 on: June 23, 2009, 05:48:30 AM »
i'm running approx 28" tyres.. and with just the 2.5" lift, the clearance is pretty close!
« Reply #132 on: June 28, 2009, 07:46:26 PM »
Is it really ok to run 31x10.50 tires on the stock (6 inch?) rims?  I have a set of 8" wide cj wagon wheels i was gunna use.
Offline bzzr2
  • 1011
« Reply #133 on: June 28, 2009, 08:17:06 PM »
ya, you'll just get frame rub a bit before full turn of the wheel.. you get used to this and how far to turn before the rub starts, not an issue to worry about and if it bugs you later you can get spacers or offset rims.  i run mine on stock wheels and it works great.
Offline blacktrack99
  • 254
« Reply #134 on: July 11, 2009, 10:48:12 AM »
Let's see if this pic comes through.  Haven't posted pics in a while.
