manual transmissions issues
  • 19 Replies
  • 4858 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: manual transmissions issues
« Reply #15 on: November 29, 2010, 02:31:31 PM »
I'm not a big fan of the magical goo's but that's just my opinion.  If you've got a quality synthetic gear oil in there than the Lucas shouldn't offer any benefit.
Offline r3cc0s
  • 321
« Reply #16 on: November 30, 2010, 10:02:34 PM »
This is quite true...
I mean its not a bad noise, and I think release bearings will always make a bit of noise...
How do you know if its possibly the clutch? (though I did replace it)
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #17 on: December 01, 2010, 04:08:26 PM »
Is it just a light scratching noise or similar?  Sorta rhythmic?
I had a '96 Ford Ranger with the Mazda M50D 5 speed stick and after having the clutch replaced at 150k it started to do that.  Went away when I pushed the clutch in.  I owned it for another 17,000 miles and it never changed or got worse.
Offline r3cc0s
  • 321
« Reply #18 on: December 11, 2010, 08:43:18 AM »
Its totally rhythmic, but seeing how the rebuild kit I saw for the clutch comes with both a bearing for both the input (release) bearing & throwout, I guess its something I'll have to do...
I'll put some lucas in the interm to see if ti helps quiet things up a little (If I can get my damned filler cap off)
« Reply #19 on: December 11, 2010, 05:59:30 PM »
The release bearing and the throw out bearing are the same thing - just two different names.
