Gv lift running 235/85 x 16's
  • 11 Replies
  • 2272 Views
Offline ZeusZuki
  • 411
« on: December 22, 2006, 09:11:30 PM »
Hi team,
Well I finally got around to fitting my Calmini lift kit. Got just under 4" of lift so decided to fit my 235/85 x 16's.
Word of warning - to fit this size rubber you need to cut a lot of internal plastic but the vehicle still retains its stock look - mission complete  ;D
No pic's - I am sure you guys have seen enough of these already  :P. Let me know if you want a pic though  ;)
ZeusZuki  8)
Offline gv1600
  • 83
Re: Gv lift running 235/85 x 16's
« Reply #1 on: December 22, 2006, 10:08:03 PM »
Thats good to hear!!
Have fun with your new setup, ......but yes.., i would love to see some good photos!!
Suzuki GV Calmini 2,5'' - Full Steel V6 Frond Diff - 205/80/16 KL71 -
4.24 t-case - T-Max 6500 - VTTR Snorkel - ProTrack Air-Lockers F/R
Offline MikeGV
  • 14
« Reply #2 on: December 23, 2006, 12:56:25 AM »
We would sure love to see some pics .
P.S. : Does Calmini make a 4 inch lift kit for GV ??? , i only know for a kit that gives you about 2 inches  ::) ::)
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #3 on: December 23, 2006, 03:28:17 PM »
we NEED pictures....
P-L-E-A-S-E
 ;D
Offline ZeusZuki
  • 411
« Reply #4 on: December 23, 2006, 08:24:26 PM »
Ok then, here are some pics. The biggest problem with these vehicles is that they have WAY TOO MUCH plastic on the inner guards  ::). So just trim it off and run some decent rubber  ;D.
Enjoy  :)
ZeusZuki  8)
Offline ZeusZuki
  • 411
« Reply #5 on: December 23, 2006, 08:27:47 PM »
More pics.
Yes the Calmini kit is only a 2.5" lift BUT as with all of their kits you get a bit more  ;)
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #6 on: December 23, 2006, 08:34:44 PM »
really nice >:D
thank you, merry christmas by the way :)
Offline MikeGV
  • 14
« Reply #7 on: December 23, 2006, 10:10:53 PM »
Cool  ;D ;D
Thx 4 the pics , Merry Christmas!!
Offline ZeusZuki
  • 411
« Reply #8 on: December 23, 2006, 11:39:54 PM »
Thanks guys. Merry Xmas to you all as well  :D
I was hoping to get a good lift but retain the stock looks - I am very happy with the results.
I know it is not everyones cup of tea to go cutting things up to fit some rubber but I see like this: You can not make an omelete without breaking some eggs LOL. I intend to fabricate some new inner skins once I am sure I have sufficient clearance.
The plan was to turn my GV into an adventure rig for myself and my family - let the good times err roll  ;D
Beerman - you ( blacknight etc, the experienced guys ) gave me a lot of inspiration to go ahead with this build  ;D. Thanks team  >:D
ZeusZuki  8)
Offline r3cc0s
  • 321
« Reply #9 on: December 24, 2006, 03:27:28 AM »
those pizza cutter sized tires are exactly what I want to run next year
I'm running 245/75/16" MTRs currently and am running a roughly 2 1/4" lift (3" rear)
and yes I had to cut splash guards and in fact had to remove my front bumper (new one being made)
However... a different approach than yours... as I am running stock control arms... I have a bit of tire rub at full lock
how is the rub w/ the Calmini lift?
I am planning on doin my 2" BL from RRO shortly, and hopefully zukination's lift will be ready by next summer for a total 6" of lift
if I do not run 235/85/16.... Trxus has a set of MT's which are 255/85/15's which measure to a  33 x 10" tire which I'd like to run
as I do have the 2.0L... I will have to run 5.38 gears, do an exhaust mod to provide adiqute power to use as a daily driver
Offline bzzr2
  • 1011
« Reply #10 on: December 27, 2006, 09:03:48 AM »
LOL - pizza cutter tires!  i've had my tires referred to that way too..
anyhow the gv looks good!
09 taco reg cab short box 4x4
Offline xoffroad
  • 153
    • PaWheelers
« Reply #11 on: January 08, 2007, 07:45:12 AM »
Euro-Esc... Is what we coined years back when Landi's were running tires that were tall, not wide.
