Tire rub on frame
  • 21 Replies
  • 6736 Views
sapien
Re: Tire rub on frame
« Reply #15 on: August 05, 2006, 11:03:12 AM »
I think I'll be ok, the new tire diameter will be at most 1" further out on either side, and there seems to be enough space at the frame with the steering wheel forced over as far as it'll go... maybe there's something different about the hubs or wheel backspacing on the XL7?  I know the front calipers are rather large so the wheel spokes have to be further out
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #16 on: August 05, 2006, 12:26:43 PM »
Your front suspension is exactly the same as mine.  Wheels are different design but the same size and backspacing.
Offline toofaroffroad
  • 226
« Reply #17 on: August 08, 2006, 06:25:28 PM »
I bought wheel spacers on ebay for 20.00$ they are aluminium quarter inch and can fit right on your stock bolts. They work great and give the extra quarter inch of width.
mozone
« Reply #18 on: August 08, 2006, 06:33:39 PM »
how do the lug nuts fit? do you still have plenty of threads to tighten up? i have thought about using the same thing to get alittle more with, thanks.
Offline mfoster442
  • 29
« Reply #19 on: August 09, 2006, 10:44:19 AM »
Toofaroffroad...
Keep us posted on how well those spacers work out.  About 1/4 inch is all that I would need to clear my tire/frame rubbing.
2002 Vitara
235/70/R16 Cooper Discoverer S/Ts
Stock engine and running gear
Boondox Spacers
Pro-Comp Shocks Strut extenders Camber bolts
sapien
« Reply #20 on: October 12, 2006, 09:57:17 PM »
got the Kumho ATs mounted, good news... no rubbing at full lock, still got a little over an inch of clearance by the frame.  will have to try it on an incline and in reverse to see if there's any issue
also it's close in the rear but it looks like I may get away with not having to trim anything.
the other good news is that these tires are significantly quieter than I expected  :)
Offline bzzr2
  • 1011
« Reply #21 on: October 13, 2006, 06:44:51 AM »
hey toofaroffroad,
how are those 1/4inch spacers working out for you?
09 taco reg cab short box 4x4
