Ride Report with New Lockright
  • 15 Replies
  • 4903 Views
Offline ShapeShifter
  • 151
  • Blaming the media for the demise of our culture...
« on: July 08, 2012, 05:25:55 PM »
Just plain awesome.
My Lockright does not make ANY noise.  It is as if it is a spool.  It does not slip at all, ever, in any condition and I am not sure why.  So off road it is awesome.  On road is fine if you don't mind the tires squealing as you make sharp right turns.
Offline AndyT3
  • 8
Re: Ride Report with New Lockright
« Reply #1 on: July 08, 2012, 07:12:15 PM »
Nice!
Cool pic too.  8)
'00 Chevy Tracker 4WD Hardtop 2.0L ~ 97,xxx
  • 151
« Reply #2 on: July 09, 2012, 09:36:23 AM »
Nice!
Cool pic too.  8)
Thanks!  I wish I had taken more pictures because we did some serious rock crawling.  All you really need is a 2.5" lift, 29" tires, a locker, and some armor and you can go most anywhere.  I dont do mud, though.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: July 09, 2012, 03:51:09 PM »
I haven't seen, but do you have an auto? Most folks say that with a lockrite in an auto you don't hardly feel it, because you don't get the driveline movement you'd have with a manual.
Heather Galvin
  • 151
« Reply #4 on: July 09, 2012, 04:03:07 PM »
Yep, its an auto.  I got AC too.  I like to crawl in luxury..... ;)
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #5 on: July 09, 2012, 04:38:30 PM »
They are a blast and add a whole new dimension to driving around off road with these trucklets.  I would never use the word "unstopable" because nothing is, but they are definitely much more capable with a locker or two.
« Last Edit: July 09, 2012, 04:41:01 PM by nprecon »
Offline diftoyota
  • 253
« Reply #6 on: July 10, 2012, 11:15:59 AM »
do they make spools for our rigs?
  • 151
« Reply #7 on: July 10, 2012, 11:25:47 AM »
Rocky Road sells one for $99.  Only available up to 2000 year model though.
I found out that mine actually is a 2000, though it is registered as a 2001.
« Reply #8 on: July 10, 2012, 11:54:52 AM »
Am I the only one perturbed by reports of the locker "not slipping, ever"?
Offline talonxracer
  • 1284
« Reply #9 on: July 10, 2012, 12:35:18 PM »
Not perturbed but concerned, sounds from his first post that it is not unlocking and is basically acting like a spool.
Offline diftoyota
  • 253
« Reply #10 on: July 10, 2012, 06:26:16 PM »
huh, 2000 and up is different? i dint know that at all. id tought it would be the same all the way up to 2004
Offline nprecon
  • 2318
  • 52
« Reply #11 on: July 10, 2012, 11:18:03 PM »
Ian has a great parts cross references to prove/dis-prove actual differences.  Personally, I still believe the manufacturers and venders are behind on their vehicle application references for their parts, particularly in the locker references.
I am currently running a Richmond Gear 1512-LR in my 2002 Tracker with a 2001 Tracker rear diff with the 1512-LR installed in it.   I have over 10K miles plus on it since install.  No problems and it works like a charm.  If I had relied on the application charts... I wouldn't have a Lock Right in my Tracker right now.
Check these year and vehicle applications for Lock Right examples:
http://www.4wheelparts.com/Drivetrain-Differentials/Suzuki-6-9in-Lock-Right-Locker.aspx?t_c=12&t_s=237&t_pt=101501&t_pl=6748&t_pn=PTX1512-LR
http://www.summitracing.com/parts/PWT-1512-LR/
http://paceperformance.com/i-6128109-lock-right-locker-powertrax-1512-lr.html
http://www.richmondgear.com/powertrax/suzukilr.pdf
http://www.catalograck.com/ImgVD/PWT/1000706MID.pdf
Also, our forum venders beat almost all the "BIG" aftermarket vender's pricing as well.
« Last Edit: July 11, 2012, 08:51:52 AM by nprecon »
Offline nprecon
  • 2318
  • 52
« Reply #12 on: July 10, 2012, 11:51:12 PM »
And yes the Lock Right SHOULD be ratcheting in corners under no power (according to Richmond Gear)... but I don't personally have experience with a 2-door truck with an automatic tranny.
It MAY be that the truck is so much lighter and that the auto tranny keeps enough pressure on his drive train that his Lock Right doesn't lose enough torque in the drive train that it will free ratchet in turns.  It may also be a problem with the actual install.  Maybe the pins and springs were crossed up during the install.  Maybe a shim issue.  I don't know.  Not enough info.
I do know when I installed mine I attempted to lean towards retaining as tight tolerance of the stock diff backlash as I could (I think the spec tolerance was between .008 in to .015 in) because I knew the Lock Right was going to add to the "play" in the drive shaft/axle/wheel movement.  A very tiny movement at the diff can translate into inches out at the tires.  I think mine was installed with around .010 to .012 back lash.  At any rate, it does free ratchet and the diff operates without excessive heat or any gear noise while driving down the road.
« Last Edit: July 11, 2012, 08:57:11 AM by nprecon »
« Reply #13 on: July 11, 2012, 10:00:56 AM »
Perturbed/concerned - same difference - the back of these trucks are light and can be wayward in slippery conditions, without any assistance from "traction aids" ;)
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
« Reply #14 on: July 16, 2012, 10:03:34 PM »
I'm concerned about it not ratcheting.  My truck (1999 5sp Grand Vitara) with lockright has never ratcheted/differentiated correctly.  I bought the entire 3rd member (Sidekick with 5.13 gears) from Trail Tough with locker pre-installed, and I just had a guy take it apart and reinstall it 3 times after an axle break (this guy does lockrights all the time).....and it CANNOT be made right.  For some reason, it will ratchet on the bench, but acts like a spool when installed in the truck.
Be aware that this can eventually lead to axle failure.  For my truck, it took several years.  Eventually, the innermost 1 1/2 inches broke off on the driver side axle.  Also, all of the pins of the locker broke and eventually scarred the diff after a big bang while backing up in a Lowes parking lot.  Tire wear gets pretty excessive when it doesn't unlock.  I was going through rear tires extremely fast.  There appears to be no fix for this.  If ANYBODY has a lockright functioning correctly in a Vitara, I would love to know what third member was used (exact year and model please), and what year Vitara/GV/Tracker/etc. it is in.  Also, which part number for the locker.  This has been a PITA for me.  Diff work in these trucks is expensive and time consuming....
That said, I wish you all the best, and enjoy your newfound extreme traction....
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
