1" Body lift/body mount question
  • 11 Replies
  • 1744 Views
« on: June 22, 2009, 12:17:12 PM »
I'm going to be doing a 1" body lift with hockey pucks.  I'm looking for just a little more articulation/flex room with my 235's.  I'm wondering how many body mounts my 03 tracker has?  From what I understand, getting into a body lift 2 inches or higher may mean extending steering/other equipment, but I figure 1 inch shouldn't require any extentions.
-Thanks
-Dan
2003 chevy tracker (2.0L-auto-2 door-soft top)
MODS SO FAR....
-235/75/15 w/cragar soft 8's
-painted grill/graphics removed
-bull bar + off road lights
-Jeff's 2" spacer lift w/new rear shocks
-flowtech muffler
-Pacer Fender Flares
Offline 2K1USGV
  • 218
Re: 1" Body lift/body mount question
« Reply #1 on: June 22, 2009, 05:06:35 PM »
Still need to extend the syeering shaft. Honestly, it's not worth the trouble for a 1" body lift, the 2" is the same amount of work and you get more lift.
« Reply #2 on: June 23, 2009, 06:04:52 AM »
Thats interesting.  So I'm going to need to extend the steering shaft reguardless of what lift?  Then I might as well do a 2" hockey puck lift.  :)
MODS SO FAR....
-flowtech muffler
Offline 2K1USGV
  • 218
« Reply #3 on: June 23, 2009, 12:10:22 PM »
Yup, you will need to extend the steering shaft for even a 1" lift. I know from experience because I bent mine as there really isn't room for even 1" of play without putting more strain on the steering shaft. I've done a body lift on my GV as well as the XL-7.
« Reply #4 on: June 23, 2009, 12:28:11 PM »
If I do a 2" lift will anything else need adjusted besides the steering shaft?
-Thanks
-Dan
MODS SO FAR....
-flowtech muffler
Offline 2K1USGV
  • 218
« Reply #5 on: June 23, 2009, 12:38:23 PM »
your bumper supports will need to be modified so you can put your bumper covers back on.
« Reply #6 on: June 23, 2009, 12:47:03 PM »
Hmmmm.....What about the rocky road 1" coil spring spacers?  It says no other modifications required.  Does this mean you can stay with your factory struts?
-Thanks
-Dan
MODS SO FAR....
-flowtech muffler
Offline 2K1USGV
  • 218
« Reply #7 on: June 23, 2009, 01:11:37 PM »
I would only reccomend these for the 2.0L. I had them on my XL-7 and they squished to about 3/4 inch. But yeah, nothing else is needed.
-Thanks
-Dan
Offline blacktrack99
  • 254
« Reply #8 on: June 23, 2009, 04:55:12 PM »
Same squishiness in a 2.0.  If you want coil spacers, there are plenty of better options on this site.  Care to chime in jeff1997?
« Last Edit: June 23, 2009, 04:56:53 PM by blacktrack99 »
« Reply #9 on: June 24, 2009, 06:11:16 AM »
I've heard Jeff makes a great product.  I may just bite the bullet and go with his setup for about 2" of lift.  Sounds like there is no quick/easy way to do a quality 1" lift.
MODS SO FAR....
-flowtech muffler
« Reply #10 on: June 24, 2009, 11:51:27 AM »
You'll be happy with Jeff's product, I am.
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #11 on: June 24, 2009, 02:35:27 PM »
He'll make you 1"ers if you want.
XL-7 front coils
1.5" rear coil spacers
