Sloppy right axle shaft
  • 15 Replies
  • 4184 Views
« on: November 14, 2009, 09:45:53 AM »
My passenger side axle shaft wobbles around pretty good on the diff side of things. I think it's time for a steel front diff. I have searched on here, and I know the answer is in here, I just can't seem to find it. Here's the question. I want to go with 5.125 gears, what years GV/Tracker am I looking for? I plan on just buying complete front & rear for an easy swap.
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Jeff's 2" spacer lift
Re: Sloppy right axle shaft
« Reply #1 on: November 14, 2009, 04:13:56 PM »
I think I found what I was looking for, just in a different forum. Now to find the parts at the pick n pull.
             89-98 Trackick gear ratios
Years....2 or 4 door...Engine type...Transmission...Axle ratio
89            2             1.3L carb.     5 speed man.  5.625
89-95       2             1.6L TBI       5 speed man.  5.125
89-95       2             1.6L TBI       3 speed auto  4.625
91            4             1.6L TBI      5 speed man.  5.375
91            4             1.6L TBI      3 speed auto  4.625
92-98       4             1.6L MPFI    5 speed man.  5.125
92-98       4             1.6L MPFI    3 speed auto  4.30
92-98       4             1.6L MPFI    4 speed auto  5.125
94-98       2             1.6L MPFI    5 speed man.  5.125
94-98       2             1.6L MPFI    3 speed auto  4.30
94-98       2             1.6L MPFI    4 speed auto  5.125
96-98       X90         1.6L MPFI    auto or man.  4.625
Offline olija
  • 770
    • Check out my cardomain
« Reply #2 on: November 15, 2009, 05:41:55 PM »
If you're looking for the 5.13 gears, they are available in most 5 speeds (the rare exception being the 8-valve 4 door and the carburated Sidekick, and a few others). 4 speed auto's have 5.13's as well.
The steel housing comes out of a V6 5 speed Grand Vitara. I think some of the auto's had them too.
« Reply #3 on: November 16, 2009, 03:29:45 PM »
You need the bushing support insert.  Contact the Suzuki Dealer parts.  Its a TSB item.
« Reply #4 on: November 17, 2009, 06:15:35 AM »
Well, I located the gears I want. I can get front and rear for $200. Now all I need to do is find a steel diff. It looks like I'll just be replacing that bushing support for now, deer season starts Sat. I went to every junk yard in the area, not one steel diff to be had.
Hey Tim, what is a TSB item? What does TSB stand for? I'll be tearing into it tomorrow and trying to locate the parts then.
« Reply #5 on: November 17, 2009, 07:15:08 AM »
TSB = Technical Service Bulletin.  In the industry, they sometimes call these "silent recalls", as you only fix the problem is the customer complains or needs the fix.
« Reply #6 on: November 17, 2009, 02:49:11 PM »
Does anybody have a parts list for this so I can order online? My local Chevy dealers won't even look up the parts so I can order them. They want me to drop it off and let them do it. All I need is some part numbers. If you sell them, let me know, I'll order right away.
Offline Rally_T-115
  • 117
« Reply #7 on: November 17, 2009, 07:31:09 PM »
The Suzuki part number for the nylon support ring is 27619-65D00.
I have a pdf of the bulletin but can't seem to find a way to upload it.  I thought maybe there'd be a spot in my profile that I could stick it.
James
1999 Suzuki Grand Vitara.
No lift or bigger tires intended.
Warn hubs. Air-SOTF circumvented.
Aftermarket4x4 front skid & fuel tank skid.  RRO Rockrails.
Waiting for: trans crossmember upgrade & skid. Contemplating: ARB rear locker.
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #8 on: November 18, 2009, 04:28:05 PM »
I did this update years ago. Worked out awsome 70,000km later and its not leaking once so ver.
01 GRAND VITARA
« Reply #9 on: November 24, 2009, 10:20:01 AM »
OK, it took an air hammer to ger the right axle shaft off, but it's out. I finally found the time to get to it, just to find out that the manual I downloaded doesn't cover the diffs. So, that adds a few questions for me to ask. Does the driver side axle shaft pull out the same as the right side? If it does, I sure hope it comes easier! And question number 2, does anybody know where to download manual # 99501-65D01-xxx? That's the number my manual says I need. The site I downloaded from is no longer there, sure wish I had known I needed another one then, free downloads are always nice!
EDIT: I got the left axle out. It came much easier than the other side.
« Last Edit: November 24, 2009, 11:12:37 AM by BackWoodsTracker »
Offline Novadon
  • 205
  • South Carolina. USA
« Reply #10 on: November 25, 2009, 11:11:39 AM »
Did you try here for the Service Manual?  ;D
http://www.auszookers.com/index.php?name=Downloads&c=16
03' Honda Odyssey
« Reply #11 on: December 02, 2009, 05:26:01 PM »
I didn't try there, thanks for the link, I'll check out the site more later. That manual is the same one I have. The one I need is a related manual covering the trannies and diffs. Manual # 99501-65D00. It shows the manual in the forward section of the manual you linked to. Now I just need to find it!
Offline Trackerprts
  • 106
  • Aiirbag
« Reply #12 on: December 02, 2009, 05:32:00 PM »
Check your e-mail.
99 Tracker pieced together out of 3 cars.             RR Body and suspension lift ,31 10.5r15
winch bumper,rock sliders
« Reply #13 on: December 03, 2009, 12:09:55 PM »
Swwet, thank you for the manual. Now I can get the thing apart and get it done. Now all I need is the time.
« Reply #14 on: December 07, 2009, 04:47:28 PM »
The gears I located were junk, so now I just want to do an easy replace. I found a front diff from a 2008 Grand Vitara 2.5 automatic. Will it just bolt into place?  I believe they were steel diffs in the later years right?
