Blowin' A/C Fuse
  • 10 Replies
  • 1134 Views
Blowin' A/C Fuse
« on: June 15, 2011, 02:48:58 PM »
I've got a 99 Suzuki Grand Vitara 2.5L V6.  I went to charge the A/C and realized the compressor wasn't spinning up.  I checked the fuse and it was blown.  I  replaced the fuse and the clutch immediately engaged and spun for a few minutes,  I went to check the pressure on the Low side and it was low,  I started filling it to pressure and the fuse blew again.  Replaced the fuse several times.  Got the system to the correct pressure. Now I just need to find out what's wrong with the electrical system.   Any body have any ideas?
Re: Blowin' A/C Fuse
« Reply #1 on: June 15, 2011, 03:52:53 PM »
If I'm not mistaken, that fuse feeds only two circuits - the a/c condenser fan and the a/c compressor clutch coil - gotta be one of those two.
« Reply #2 on: June 16, 2011, 10:03:55 PM »
When that happened in my 2001, it was the fan that was blowing my fuse. I'd check that first. I hear it's a fairly common thing with these.
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Jeff's 2" spacer lift
Offline trackinstile
  • 435
  • Too young to quit........Too old to change........
« Reply #3 on: June 17, 2011, 02:18:58 AM »
It may be the fan, I hit a deer, and the fan seemed ok, but was seized, it kept popping the fuse.
A wise man once said, "Wherever you go...........There you are.............." 2000 Tracker 4 door with the 2.0 liter "Big Block". 5 speed 4WD  2001 XL-7 EX II
Offline IanL
  • 466
« Reply #4 on: June 19, 2011, 01:58:08 AM »
Not quite, it's only the Condenser Fan.
The clutch coil power comes from the Rear Defogger fuse!
« Reply #5 on: June 19, 2011, 11:36:56 AM »
When the fuse blows the Compressor clutch disengages though?
« Reply #6 on: June 19, 2011, 12:26:22 PM »
Ummm - not according to my FSM - fuse #29, A/C fuse feeds both the a/c fan & a/c compressor clutch coil via their respective relays - of course we could be looking at different vehicles or different diagrams.
But then again - having looked at four different sets of drawings - all are like that - just the fuse number changes.
Offline IanL
  • 466
« Reply #7 on: June 22, 2011, 01:12:55 AM »
Oops, you're right.
I misread a 3  - thought it was a 9.
« Reply #8 on: June 22, 2011, 02:54:41 PM »
Should the condenser fan spin freely with the engine/power off?  Mine does not.  I think this might be my culprit.  Thanks guys!
« Reply #9 on: June 22, 2011, 05:58:43 PM »
Yes it should.
« Reply #10 on: June 26, 2011, 03:41:17 PM »
Just to update in case anyone else has this issue. ..
My condenser fan was locked up.  That was blowing the 25Amp A/C fuse.  I unplugged my fan, replaced the fuse and the A/C worked fine.  Replacing the fan this week.
Thanks for the help guys!  You're the best!
