Tire rub on frame
  • 21 Replies
  • 5834 Views
Offline mfoster442
  • 29
Tire rub on frame
« on: July 31, 2006, 10:42:34 PM »
My 235/70/R16s rub slightly on the frame (back of tire...not front) when the steering is fully locked (forward or reverse)
Is there anything that can be done other than wheel spacers?  I don't want a full inch of wheel spacing, as it is not rubbing very much.
Any suggestions or experience with this?
Thanks.
2002 Vitara
235/70/R16 Cooper Discoverer S/Ts
Stock engine and running gear
Boondox Spacers
Pro-Comp Shocks Strut extenders Camber bolts
Offline bzzr2
  • 1011
Re: Tire rub on frame
« Reply #1 on: August 01, 2006, 07:14:05 AM »
mine does the same, can't think of anything other than spacers or new wheels that would help..
09 taco reg cab short box 4x4
Offline nils
  • 66
  • Team Tincan!
« Reply #2 on: August 01, 2006, 07:27:41 AM »
maybe you can reduce the maximum stearing angle? turning radius will increase, but ur frame is cleared.
Offline mfoster442
  • 29
« Reply #3 on: August 01, 2006, 07:58:40 AM »
Are there any particular wheels out there that anyone is aware of that work?
I guess wheel spacers would be okay...has anyone had any problems with these?  Would there be a preference between Spidertrax and the ones offered by Rocky Road, or are they the same?
Would it be totally crazy to modify the frame?
Thanks for all the help.  This place is great.
Best,
2002 Vitara
Boondox Spacers
mozone
« Reply #4 on: August 01, 2006, 05:13:04 PM »
i have the same seyup on a 2001 zr2. 15" rims it rubs a little at full lock but is not a problem just sound kinda strange. the frame has a rounded edge and it has not messed any thing up, you hjust need to be aware of it. it has been like that for two years no promlems. good luck!
Offline mfoster442
  • 29
« Reply #5 on: August 01, 2006, 10:31:13 PM »
While I was reinstalling my swaybar this evening, I noticed something interesting.
My tires are rubbing where the sway bar mounting surface is welded onto the frame.  It appears there would be plenty enough material to grind a bout .25-.5" (that's all I'd need for clearance) and not actually bite into the frame...just the very back of the big plate they welded onto the frame.
I'll look at it quite a bit more closely.  Hopefully it will be feasible rather than going with spacers.  :-\   I'll keep the progress posted.
I took a picture, but I'm not sure how to post it...
2002 Vitara
Boondox Spacers
Offline aceluck
  • 30
« Reply #6 on: August 02, 2006, 01:37:36 PM »
Thanks.
what if any lift are you running, or is your truck stock height? Is your Vit 2L 4 Cylinder?
I'd like to know cause I have a 2002 Tracker, no lift, 2L and if these tires fit, I'm going to get some. (thought I'll probably got 225/70-16)
Offline bzzr2
  • 1011
« Reply #7 on: August 02, 2006, 01:56:33 PM »
no matter what lift the tires will rub the frame at 30's and up on full lock with stock rims.  very lightly but enough, my 31 tsl rub the frame with 3.5 inches of lift!  spacers or offset rims!!!  go with the biggest that clear your fenders and don't worry about a slight frame rub.  just pay attention when turning.
Offline mfoster442
  • 29
« Reply #8 on: August 02, 2006, 02:05:49 PM »
Aceluck...
I have the Boondox lift, which I believe amounts to around 2".  My Vitara is the 2.0L.  I had good luck with the Suzuki 4cyl before (178K in my previous rig and it was still running strong)
I believe Bzzr2 is right...now matter what the lift (reasonable life anyway) the tires will rub at around 29"
My 1996 Sport had the same tires I have now, and it rubbed slightly before and after a lift.
I'm pretty sure I'm going to grind a little bit of the bracket to make some clearance, smooth it out, and what little rubbing is left should be fine.  I can do this without touching the actual frame.
I'll post a photo when I figure out how...  ;)
2002 Vitara
Boondox Spacers
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #9 on: August 02, 2006, 05:55:50 PM »
We have the same "rubbage" with our 2003 GV.  It only seems to happen at max lock in either direction.  I'm not terribly worried about it.  Doesn't sound very pleasant but so far the tires are fine.
I've seen thin spacers, less than 1/4", in some parts stores before.  I'm tempted to go find a set and see how they affect the rubbage but then the wheel studs aren't very long and I don't know if I want to further shorten them via wheel spacers.
At any rate I'm not that worried about it.
sapien
« Reply #10 on: August 02, 2006, 07:10:20 PM »
Is this primarily an issue with mud/offroad tires with bigger tread blocks?  I am about to go to 235/70/16 on my XL7 but it seems that some tires are shy of 29" in that size.  (in fact I looked at some Michelin Cross-Terrains and unmounted they were closer to 28")  the ones I'm buying are Kumho Road Venture AT's
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #11 on: August 02, 2006, 08:52:01 PM »
I think it's mostly a function of the height of the tire.  Some of us have this with 225/75R16's and others report it with 235/70R16's.  I bet if you crank your stock tire right now and look back there next to the frame there's less than an inch of clearance.  Now add a 1-2" taller tire and you'll see where it'll get close.
I do wonder if a less aggressive tire without lugs would bite.  My bet is that it would, but not as much.  Mine's just a smallish spot on both sides and I have no apparent tread damage...but I can't imagine a less aggressive tire in the same size would be that much smaller/narrower that it would miss completely.
Maybe try a 225/75R16 or 225/70R16 in an AT?
Offline bzzr2
  • 1011
« Reply #12 on: August 03, 2006, 08:23:12 AM »
i can say that when my tsl's rub it is very noticable cause the lugs are so big, it feels pretty rough in the steering wheel.  i had the same issue with my 30" coopers.   i only cranked it for a test to see how bad it was.  whenever i get wheel spacers i'll let you guys know how that goes.  it'll be a while though i imagine, i'll be wheeling it good this weekend and if i notice any stability issues i may make this happen sooner..
sapien
« Reply #13 on: August 03, 2006, 06:13:55 PM »
thanks for reminding me to check, I guess I was assuming it wouldn't be an issue at this size... looks like I'm in luck with the XL7, the stock 235/60/16 clears the frame by at least 2 inches at full lock.  those are nearly new / full tread so I don't think I'll have any issue going to 235/70/16.  plus I'm putting in a 1-1.5" lift so they should clear the fenders nicely too   :)
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #14 on: August 04, 2006, 04:04:59 PM »
I bet you'll still rub a little.  Remember that while the width will be the same that width will now be an inch or so further out and closer to the frame.
