GV 4.5" lift
  • 942 Views
Offline eyb
  • 84
  • I love YaBB 1G - SP1!
GV 4.5" lift
« on: September 08, 2009, 01:52:06 AM »
In relation to the recent post of harsh ride using Pro comp ES 1000. Another concern is the "humming" sound of the propeller shaft. I used 3/4" T6 shafting spacer on the propeller shaft to compensate for the lift, had a 3/4" lowered transfer case cross member fabricated but still encounter the humming sound.
I suspect the need to lower the transfer case crossmember. Has anybody experienced the same problem? I welcome inputs
Offline blacknight
  • 987
    • Gonzookin
Re: GV 4.5" lift
« Reply #1 on: September 08, 2009, 06:59:57 AM »
did you adjust you pinion angle?
Offline eyb
  • 84
Re: GV 4.5" lift
« Reply #2 on: September 08, 2009, 07:56:55 PM »
pinion angle was retained. from the angle of inclination of the propeller shaft going to the transfer case is gradual, not steep with no stress points on the yolks.
