Vitara Gear swap
  • 2075 Views
Offline Carter125
Vitara Gear swap
« on: September 28, 2019, 12:44:19 PM »
Hello,
I'm currently in the middle of installing the altered ego 4.5 lift into my 2 door vitara. (5 speed manual). I'm looking for information onto which ring and pinion gears will swap into my housings? I'd love to gear mine to 5.12s,  can I use gears out the the later 1st gen trackers/side kicks? I'm having troubles finding gear sets/ information on what will swap over.
Thanks!
1999 Vitara 2 door
4.5 altered ego lift
5.12 gears
Lockright locker (rear)
31 inch tires on 15 inch rims
Re: Vitara Gear swap
« Reply #1 on: October 11, 2019, 02:54:49 PM »
I don't think it is a direct swap, Fordem would be the one to send a message to.
But I believe the Automatic Vitara has the 5.125 gears in them as well, so you can just track down an auto
Offline Browning
  • 24
« Reply #2 on: August 30, 2020, 08:26:12 AM »
I swapped out to pre-99 gear sets so I have more options for gear sets, however the front requires a custom CV shaft as location slight changes, Alter Ego did this for me, best think I’m all mechanical, locking hubs and no vacuum pump! Mint
I like tight lines, big racks and sweet lines, I’m just a sofisticated Redneck!
