need help engine stutter
  • 19 Replies
  • 3506 Views
0 Members and 44 Guests are viewing this topic.
Offline chocolatemilk
« on: March 02, 2011, 12:34:55 PM »
I just bought a 87 samurai and it started stalling on me. I replaced fuel filter and it runs better but it still stutters. Any ideas please help. Thank you
I Like Chocolate Milk
Offline hazmat
  • 12
Re: need help engine stutter
« Reply #1 on: March 02, 2011, 01:19:29 PM »
I got a 86 and 88.  The 88 was doing the same thing. If you still got the stock carb there are vent tubes on the drivers side of the carb under the breather.  Make sure they are hooked up.  Hope that helps you if not check all the vac hoses.  also check the sparkplugs and the wires.  If I think of any thing else will let you know.
« Reply #2 on: March 02, 2011, 01:51:42 PM »
Its an aftermaket carb. I replaced the spark plugs and the cap and roter. My freinds think im running lean.
but thank u i appreciate it I will look for any vacuum leaks.
« Reply #3 on: March 02, 2011, 06:00:06 PM »
What type of carb do you have installed?
« Reply #4 on: March 02, 2011, 07:58:19 PM »
I think its a weber.it was on it when I bought it.
« Reply #5 on: March 06, 2011, 01:45:19 AM »
Are you seeing the issue all of the time or just during specific operations, like cruising down the highway or once the car warms up?
« Reply #6 on: March 07, 2011, 09:21:20 AM »
Its all the time.
« Reply #7 on: March 08, 2011, 01:29:50 PM »
Are you running the stock fuel pump or an electric one?  You might have a fuel delivery issue with either to much or not enough pressure.  It might also just need to be adjusted.
« Reply #8 on: March 09, 2011, 02:30:03 PM »
The guy I got it from said it was a new fuel pump. Can I use an electric fuel pump from a sidekick. I have one but I didn't know if it was to much pressure for the carb.
Offline tipover
  • 422
« Reply #9 on: March 09, 2011, 08:26:30 PM »
you want 3-5 psi.   Fuel injection pump are 40+  Float level? never had a weber but i assume it has a float? hows your timing?
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
« Reply #10 on: March 09, 2011, 10:15:51 PM »
He said that the carb is pretty new I don't really know how to adjust the float or the carb air fuel mix. And I lost my timing gun so I can't check that yet.
« Reply #11 on: March 10, 2011, 02:52:21 PM »
If you are using the stock pump then you will want to put a fuel regulator in between the pump and the carb.  I believe the Webbers run about 2 lb's.
« Reply #12 on: March 10, 2011, 04:42:53 PM »
ok i will try that and let u know how it goes. :)
« Reply #13 on: March 15, 2011, 10:49:17 PM »
It was my break booster
« Reply #14 on: March 15, 2011, 11:13:16 PM »
Vacuum line hooked up wrong?
