1990 tracker front springs VW diesel
  • 4333 Views
Offline ianskian
« on: January 12, 2016, 12:11:30 PM »
Hi,i have a VW 1.9 turbo in my 2dr Tracker it has 2 inch coil spacers but still seems slightly low in front end, any suggestions welcome.....maybe 4dr springs which may be too much axle angle?
« Last Edit: January 16, 2016, 01:18:33 PM by ianskian »
Offline WILD_PHIL
Re: 1990 tracker front springs VW diesel
« Reply #1 on: January 24, 2016, 01:53:14 PM »
Got any pics?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Offline sdubfid
  • 15
« Reply #2 on: January 24, 2016, 08:32:42 PM »
I ran stock with spacers and 1.6td with no issues.  Also ran ome struts and 962 springs with 955 rear springs and 3/4" spacers.
94 Sidekick 4 door, 1.6vw turbodiesel, 37mpg
Offline ianskian
« Reply #3 on: January 25, 2016, 10:20:05 PM »
Forgive my bad but what are 962 springs?,my front end is probably a little heavier as I have an extra battery plus front tow bar skid plates etc.
« Reply #4 on: January 26, 2016, 05:10:46 AM »
962 or 2962 is an OME (Old Man Emu) spring part number - specifically - it is the "heavy" front spring offered for the SQ series Grand Vitaras (98~05) - it's also used on the diesel engine XL-7s.
Full details - length, wire size, spring rate, etc. are available from Old Man Emu or ARB.
Offline ianskian
« Reply #5 on: February 01, 2016, 10:24:32 AM »
Ok,thanks,I'll look into those 962's :sleepy: :-*
« Reply #6 on: February 02, 2016, 11:56:24 AM »
I am running the 956 springs in my 93 2door.  while they are 0.4" longer their rate is 40 lbs/inch lighter.  My motor is around 340 lbs, probably a little heavier.  The 962 springs are rated at 540, which is 100 lbs/inch heaver than stock.  I wouldn't want heavier springs than I have, and the length can always be cut back, you cant reduce the heavier rates.
Here is a link to the spring rates from Low Range Offroad http://www.lowrangeoffroad.com/images/charts/front_springs_chart.jpg
