235s on 15x8s?
  • 1784 Views
Online Thirty-Nine
  • 285
    • Subcompact Culture
235s on 15x8s?
« on: May 17, 2011, 05:07:35 PM »
I had originally planned on getting some 15x7s, but I might have found a good deal on some 15x8s. If I put 235s on the 15x8s, can I expect a lot more rubbing? I suppose a lot of it will have to do with backspacing, etc., but is there a general rule of thumb?
Offline Dayton86
  • 35
Re: 235s on 15x8s?
« Reply #1 on: May 17, 2011, 07:06:44 PM »
Its all going to depend on the offset/backspacing. I don't know what it is on mine but the front rubs a  bit and the rear is chunking the lugs a bit. If it does rub a little lift is easy enough, not to get mine on.
Online Thirty-Nine
  • 285
Re: 235s on 15x8s?
« Reply #2 on: May 18, 2011, 07:18:02 AM »
OK, thanks. Got any pics of your setup?
Offline Dayton86
  • 35
Re: 235s on 15x8s?
« Reply #3 on: May 18, 2011, 08:24:54 PM »
Pics with some lift if you want tomorrow, finished the install after dark.
« Last Edit: May 23, 2011, 04:40:53 AM by Dayton86 »
Online Thirty-Nine
  • 285
Re: 235s on 15x8s?
« Reply #4 on: May 19, 2011, 07:36:19 AM »
Do you know what kind of offset and backspacing you've got on those? (Always loved that wheel style)
Offline Dayton86
  • 35
Re: 235s on 15x8s?
« Reply #5 on: May 19, 2011, 09:22:05 PM »
Unsure on backspacing and such, the previous owner put them on. I just put on the tires.
Here is it with 1.5 up front and 1 in the rear.
Re: 235s on 15x8s?
« Reply #6 on: May 20, 2011, 07:26:08 PM »
Looks better.  Once you have lifted them stock looks kinda worn down.
