brakes keep locking up
  • 18 Replies
  • 8633 Views
Re: brakes keep locking up
« Reply #15 on: September 01, 2011, 09:29:18 AM »
Yes the bleeder is on the bottom, that picture was taken looking up.
Did it come from the factory like that?  It looks like it would make bleeding quite difficult.
I suspect the bleed nipple is intended to bleed air from the front brake circuit (the line closest the bleed nipple) but if thats the original position then I would also want to think the rear brake lines are reversed top/bottom, since the supply line is at the top and the line to the axle at the bottom.
Edited to correct spelling
« Last Edit: September 01, 2011, 03:49:20 PM by fordem »
« Reply #16 on: September 01, 2011, 01:49:20 PM »
It sounds like the brake booster is having issues or isn't getting vacuum...
vacuum is getting to the booster, every time I take the hose off of the booster it kills the motor.
« Reply #17 on: September 01, 2011, 06:22:11 PM »
That doesn't sound right. I know a vacuume leak will make a motor run crappy, but kill it? I'm gonna have to check that on mine. I still think it's in the master cylinder to vacuume booster fit.
Offline talonxracer
  • 1284
« Reply #18 on: September 01, 2011, 07:17:49 PM »
Yes it came like that from the factory, the bleeder is parallel to the ground and points towards the fuel tank. Those lines had never been removed from the condition/looks of them, the bends are perfect and factory. I will check them out for where what goes in the AM and post the results, I am a bit intrigued myself.
I apoligize to the TS for the slight diversion.
« Last Edit: September 01, 2011, 07:19:21 PM by talonxracer »
