front end noise
  • 13 Replies
  • 3329 Views
front end noise
« on: March 10, 2011, 09:18:50 AM »
So I installed a coil spacer lift. After doing so im having noise in the front end going over bumps. When I installed the new front struts (factory), i noticed that the front diff assembly was wiggly and I could move it side to side. Could this be my noise issue? What is usually taking up the slack in that assembly?
Offline MUD_TRACKER
  • 28
  • muddin in the ole tracker
Re: front end noise
« Reply #1 on: March 10, 2011, 09:30:55 AM »
Yea very well can be. Did you tighten you swaybar and you tie rod end back up? Your axle come out(4x4) equip.
what model tracker is it?
Just look over the bases and trace your steps and hopefully you will solve ur problem
Re: front end noise
« Reply #2 on: March 10, 2011, 12:25:51 PM »
its a 97 sidekick 4 door 1.6l 5 speed.
The sway bar was disconnected but is back togeather. The right axle did come out to install the struts. Ill check to make sure it has not poped back out.
Re: front end noise
« Reply #3 on: March 10, 2011, 02:51:23 PM »
Did you put a set of strut spacers on along with the spacer lift?
Offline MUD_TRACKER
  • 28
Re: front end noise
« Reply #4 on: March 10, 2011, 03:09:17 PM »
Yea I left that out. Ur struts could be fully extended.could be riding.like crap. If not u might wanna find a set it some longer struts like OME from rocky-road
Re: front end noise
« Reply #5 on: March 10, 2011, 10:52:46 PM »
I built 2." strut spacers to match the coil lift.
Offline MUD_TRACKER
  • 28
Re: front end noise
« Reply #6 on: March 11, 2011, 08:36:29 AM »
Im gonna say u made 2" rear and 2"front spacers? If so you need to take the front down a inch. I installed a 2" spacer kit last week on my tracker and the front coil and strut is 1.5" and rear is 2" and have no sounds. You CV's could be the problem.
Re: front end noise
« Reply #7 on: March 11, 2011, 10:47:57 AM »
2.5" coil spacers on rear. 2" coil spacer front. 2.5" strut spacer front. 2.5" total lift. There is tons of travel in the strut still. The cvs are not the issue cause they are not even engaged. This is just street driving. stutter bumps
Offline MUD_TRACKER
  • 28
Re: front end noise
« Reply #8 on: March 11, 2011, 08:15:34 PM »
Did you set the coil springs were the very end of the coil is touching the metal. Kinda hard to explain. Its on the bottom.
Re: front end noise
« Reply #9 on: March 12, 2011, 12:42:17 PM »
Yeah, the springs are set in the notches in the bottom.
Offline DonD
  • 140
Re: front end noise
« Reply #10 on: March 12, 2011, 01:00:06 PM »
You say the diff is wiggling around..Sounds like you need to put her in the air and have a good looksee. Sounds like your diff mounts are failing/loose/broke.
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
Re: front end noise
« Reply #11 on: March 12, 2011, 05:13:34 PM »
Im bringing it into the shop at school next week, so Ill check her over good then.
Re: front end noise
« Reply #12 on: March 13, 2011, 04:29:22 PM »
You are right at the limit for your front end, anything over a 1.5" front spacer tends to cause the CV's to fail when off-roading.  So be a bit careful your first few times out when climbing hills.  Let us know what you find out when you crawl under it.
Re: front end noise
« Reply #13 on: March 13, 2011, 04:58:33 PM »
Well we are going on a bit of an expedition this weekend. Still plenty of snow here so I dont know how much we will be able to do, but ill keep you posted.
